harmonic balancer Replacement?
Old Aug 20, 2008 | 09:56 PM
Sup2jzgte's Avatar
Sup2jzgte
Default harmonic balancer Replacement?
How do you know when you need to have your harmonic balancer replaced?
Old Aug 21, 2008 | 01:25 AM
Cleanshots's Avatar
Cleanshots
"crank pulley" and when it goes bad, dont fix it unless its broke..
Old Aug 21, 2008 | 01:16 PM
SC300_704's Avatar
SC300_704
whenever it starts to make a loud screeching noise like a belt that is going bad and then just fall apart like mines a few days later...
Old Aug 21, 2008 | 01:47 PM
93MSB's Avatar
93MSB
there is a small rubber ring that you can see on the front of the pulley. If its badly cracked, hard, or brittle, you might want to consider replacing it.
Old Aug 22, 2008 | 05:42 PM
JspecSC3's Avatar
JspecSC3
Correct!
Old Aug 23, 2008 | 01:41 AM
tcd300's Avatar
tcd300
i replaced mines with a light weight under drive crank pulley not damped and it cost about 120. if you plan on replacing it with a really good one go with like ati damped pulley those things will never go bad. you know when its bad when it whines when you start up the car it can be your idler pulley or your cranked.
Old Aug 25, 2008 | 10:24 AM
cbrasian's Avatar
cbrasian
easier way if your alternator isn't charging the car well and the alternator is good yet car keeps dying and you know that battery is good you can thank your harmonic balancer for that....
Old Aug 27, 2008 | 04:05 PM
js93sc3's Avatar
js93sc3
The best way tp prevent costly repairs is to prevent it from happening. If the inner rubber is cracked, replace it. My crank pully came off while I was driving and broke my fan and shroud and dented my rad. So its best to prevent it from happening.
mark98ls40
15
Apr 29, 2024 12:25 PM
Dresskell
Aug 30, 2016 02:24 PM
synrgy350
Apr 22, 2016 04:11 PM
lexrally
RX - 1st Gen (1999-2003)
Mar 10, 2016 06:12 AM
JayCaz
Apr 4, 2011 06:13 PM
