Anything else I should do while installing Tein SS?
Old May 21, 2008 | 06:32 PM
sneakyazn's Avatar
sneakyazn
Default Anything else I should do while installing Tein SS?
I am going to be having a shop install my Tein SS coilovers from a Supra onto my SC400. Is there anything else you would recommend me having them do at this juncture? Also, is it ok to use the stock mounts? My car has 85k on it so I'm not sure if I need to swap out the bushings etc.
Old May 21, 2008 | 07:53 PM
FormosaSC's Avatar
FormosaSC
swap out the control are bushings while you're at it. It's a good idea to do so because you'll need another alignment when you change the bushings out again
Old May 21, 2008 | 08:00 PM
818sc400's Avatar
818sc400
checkout the sway bar endlinks also. you might need to swap them
Old May 21, 2008 | 08:01 PM
PlatanoTLS's Avatar
PlatanoTLS
Paint your calipers
Old May 21, 2008 | 08:37 PM
sneakyazn's Avatar
sneakyazn
For the control arm bushings, should I do fronts and rear? Or is one more prone to having issues than another? Also, do you think its ok to use the stock mounts with the coilovers? Those Tein mounts are quite pricey and I read that they don't add much because of the double wishbone suspension. Of course that is all regurgitation as I don't know what any of that means! :-.
Old May 22, 2008 | 04:48 PM
One_jZ_SC3's Avatar
One_jZ_SC3
Originally Posted by PlatanoTLS
Paint your calipers
I second that
Old May 22, 2008 | 05:43 PM
RikTT's Avatar
RikTT
Consider brake pads /rotors or steel braided lines (optional) unless youre just concentrating on suspension stuff
Old May 22, 2008 | 07:14 PM
aka paco's Avatar
aka paco
why would you need to paint the calipers?
eskay269
15
Jun 16, 2011 02:59 PM
bmsport
Jan 30, 2006 07:59 PM
soarer479
Oct 7, 2004 04:34 PM
SinisterSC
Jun 17, 2003 08:46 PM
