DIY homemade polyurethane
Old Jan 21, 2008 | 06:22 PM
rawdil49's Avatar
rawdil49
CL Folding 25,000
Default DIY homemade polyurethane
i just came across this interesting article to make your own polyurethane engine mounts. has anyone tried this?
http://www.superhonda.com/forum/showthread.php?t=204274
Old Jan 22, 2008 | 06:59 AM
vipsoarer's Avatar
vipsoarer
it works as i did this to my honda... only problem is that the original cracked rubber still sits within the newly filled mount and causes it to deteriorate. your best bet is to trace where the mount hole goes and remove all the old rubber then replace. It is a good upgrade when replacing the trans mount to fill the holes and gaps. be aware your car will vibrate much more with the urethane in the mounts.
Old Jan 22, 2008 | 09:47 AM
VJZ's Avatar
VJZ
I did it to my old Celica a few years ago. They worked nice and are a great alternative if you can't afford new stuff--like me!
Old Jan 22, 2008 | 10:32 AM
tavarish's Avatar
tavarish
https://www.clublexus.com/forums/sho...d.php?t=275695
DIY mounts.
Old Jan 22, 2008 | 12:50 PM
RedPhoenix's Avatar
RedPhoenix
I did the mounts on my Camry, worked well, but the top mount seemed to rip apart easy.
Old Jan 23, 2008 | 04:27 PM
FormosaSC's Avatar
FormosaSC
ive seen people use hockey puck for engine mounts...
Old Jan 24, 2008 | 01:16 PM
Sc dRifta's Avatar
Sc dRifta
*****Do not buy from this member until further notice *****
fyi i use hockey pucks on all custom swaps i do ie: rb and 2jz motors in weird cars with custom welded mounts. they work great!!!! i stack 3 hockey pucks and liquid nails all 3 of them together. then drill a hole in the middle and use a grade 8 or higher stud makes a great solid mount with just enough to absorb major engine shaking but still feels solid when your behind the wheel. ive been testing this setup for about 2 1/2 years now i check the mounts daily on all the cars ive installed on thats a total of 4 and there have been no signs of deterioration
Old Jan 24, 2008 | 01:35 PM
FormosaSC's Avatar
FormosaSC
ive been thinking of doing this... but i decided not to because i dont want to list my mods nice pictures of my car and one of the line says:
custom motor mounts (hockey puck)
Jaycee22
RX - 1st Gen (1999-2003)
Jun 15, 2016 05:09 PM
mandyfig
Nov 2, 2015 05:40 PM
pbbnxiltae
Nov 10, 2007 06:34 AM
vinny186
Nov 23, 2006 11:18 AM
CleanSC
Apr 7, 2004 10:00 AM
