New Squeeks...
Old Jan 8, 2008 | 08:35 PM
lexSCus's Avatar
lexSCus
Default New Squeeks...
I've heard this on many cars, and mine usually only did it after a rain. now here in San Diego it rained for a week (WTF????) and my car now has a squeek that seems to match the RPM speed. more RPMs = Faster squeeking.
Seems to be coming from one of the pullies on the right side when facing head to head with the car. Left side from driver's view. Any help???
Old Jan 8, 2008 | 08:43 PM
fwynn's Avatar
fwynn
only thing i can say is.. how can rain affect the pullies? since the pulles are under the hood.. and away from the water..
Old Jan 8, 2008 | 08:52 PM
andrewwake's Avatar
andrewwake
If he doesn't have the under engine plastic part that could allow for the water to get in there. Or just it being more humid in the air from a week long rain that the car is not used to.
Old Jan 9, 2008 | 10:42 AM
lexSCus's Avatar
lexSCus
Default ssoooo
any ideas for a remedy??? or should i just try to get the stealership to diagnose a simple problem for astronomical prices?
Old Jan 9, 2008 | 10:49 AM
vwynn's Avatar
vwynn
if its one of the pullies... check which pully is making the sound and then replace it?
Old Jan 9, 2008 | 11:03 AM
ChronoJ1's Avatar
ChronoJ1
Mine does that too when it's cold/humid. Annoying as hell.
All my pullies are rusted and ugly. Are brand new replacement pullies expensive? Any aftermarket support?
Old Jan 9, 2008 | 11:37 AM
VJZ's Avatar
VJZ
Whoops didn't see this one.
We probably have the same problem. Check your fan blade pulley. I can't see it being the crank pulley or underdrive whatever its called.
Old Jan 9, 2008 | 05:47 PM
Gunnar's Avatar
Gunnar
I have full Unorthodox pulleys (crank, water pump, power steering, and alternator)
Old Jan 9, 2008 | 05:57 PM
ChronoJ1's Avatar
ChronoJ1
But i'm assuming you have a 300.
Old Jan 10, 2008 | 12:57 AM
Luke_in_SD's Avatar
Luke_in_SD
my 400 used to squeak in morning for like 5 mins it was cold outside. But ever since I changed the drive (serpentine) belt, it hasen't squeaked since. not bad for $25
Old Jan 10, 2008 | 06:23 AM
ChronoJ1's Avatar
ChronoJ1
It's not a slipping sound coming from the belt, and my belt is only 15000 mi old.
Old Jan 10, 2008 | 07:51 AM
BLK13X's Avatar
BLK13X
For Mind Cruising
I had a noise which was similar to yours... Mine threw an idler pulley bearing... and it chewed through my drivebelt.
Old Jan 10, 2008 | 03:06 PM
jm94tt's Avatar
jm94tt
I'll 2nd on the idler pulley bearing. Remove the serpentine belt, make sure the bolt holding the pulley to the tensioner is tight (left hand threaded), and grasp the pulley and try to rock it back and forth. There should not be any play. Also, spin the pulley by hand, if the bearing sounds "dry", it is toast. The bearing can be replaced without bending over for the complete tensioner assy. The bearing part number is 6203. Costs around $3-$6.
GSTONY
Sep 6, 2012 02:51 PM
User 121523
Oct 13, 2009 10:51 PM
roy1928
Automotive Care & Detailing
31
Dec 31, 2007 12:54 AM
CareyPJ
Jan 18, 2005 01:59 AM
Lexson
Sep 7, 2002 02:20 PM
