When installing TT wheels......?
Old Nov 20, 2007 | 07:43 AM
turbohye's Avatar
turbohye
Default When installing TT wheels......?
Hey guys. Just curious. When installing TT wheels (the 17s) on a stock body, stock height, sc300 with stock brakes (basically all stock) does anything have to be done to accommodate the wheels. From what i understand they bolt up with no problems correct? I dont believe one would need spacers or hubcentric rings right? Thanks in advance
Old Nov 20, 2007 | 09:58 AM
Blizzy's Avatar
Blizzy
The Supra hub is identical to the SC hub in diameter (no centering rings needed).
The lug pattern is the same, and your factory SC lugs will work on the wheels (no need to buy new lugs).
You can fit 285's in the rear on stock unrolled fenders, and 245's up front on stock unrolled fenders (255's will fit on a 17x8, but they will rub the suspension unless you run spacers).
You should run into exactly zero difficulties.
Old Nov 20, 2007 | 10:17 AM
TheMole's Avatar
TheMole
Only thing you would have to worry about is smiling when you see how good they look.
Old Nov 20, 2007 | 11:24 AM
habitat's Avatar
habitat
I thought the supra offset was slightly off???
"Supra wheels will fit the SC coupe perfectly; However, the offset is slightly less in Supra wheels (Lexus +50mm, Supra +38mm). This is not a substantial enough difference to create steering issues, but the wheels will look like they are tucked in by a little under an inch. This difference can be remedied with H&R 15mm spacers. Supra TT wheels are 17x8F and 17x9.5R, while the Supra NA wheels are 16x7.5. Both sizes are offered in chrome, polished aluminum, and silver finishes." (link)
Old Nov 20, 2007 | 12:12 PM
mkorsu's Avatar
mkorsu
Zombie Slayer
They'll be less tucked than stock Lexus rims, that's for sure.
The reference intellexual is making is in regards to an aggressive/flush fitment. You would need to space out the TT rims in order to be perfectly flush. But if someone is concerned with being perfectly flush, just get wheels made to fit!
Old Nov 20, 2007 | 01:59 PM
turbohye's Avatar
turbohye
Smile
Thanks Guys i really appreciate the input. You guys provided me with a wealth of knowledge in just one posting so i hope the best to you on your holidays.
-Tony
Old Nov 20, 2007 | 04:24 PM
Blizzy's Avatar
Blizzy
Supra wheels use a +50 offset all around. This is misinformation.
Old Nov 20, 2007 | 04:49 PM
habitat's Avatar
habitat
Misinformation on intellexual? Thats my lexbible, now where will I go for lexlightenment??
Old Nov 20, 2007 | 10:53 PM
5sp_jzz30's Avatar
5sp_jzz30
blizzy is right the mk4 tt wheels are 17x8+50 and 17x9.5+50 not whatever intellexual says. stock sc wheels are 16x6.5+50(at least the ones i got)
put a 25mm spacer on the rear and 15mm front and it will be nice.
search and you will find a thread just recently on how the tt wheels look on an sc with and without spacers.
good luck
j3ff
IS F (2008-2014)
Jul 29, 2016 11:31 AM
36Chambers
Jan 25, 2009 11:01 AM
nism0
Aug 17, 2004 08:54 PM
oldmonk
Wheels, Tires & Brakes Forum
Aug 25, 2003 11:48 AM
ryanSC300lover
Dec 18, 2002 11:37 AM
