need help with offset
Old Jul 17, 2007 | 09:42 AM
xx69xx's Avatar
xx69xx
Default need help with offset
okay so i found some rims for a good price 19x8.5 in the front and 19x9.5 in the back the guy doesnt know the offset he said he had them on his 3 series BMW with no rub at all any one know if theese will fit my car or what the offset is?
Old Jul 17, 2007 | 09:50 AM
Deceptik1's Avatar
Deceptik1
BMW has different lug spacing. 5x120 versus our 5x114.
Old Jul 17, 2007 | 09:51 AM
xx69xx's Avatar
xx69xx
so id need an adapter? how much would that run me?
Old Jul 17, 2007 | 10:14 AM
Blizzy's Avatar
Blizzy
not worth it.
look for other wheels with the proper lug pattern. Check out G35, Z350, RX7 forums. There are some pretty sexy wheels on their forums just like their are some pretty sexy wheels on ours.
Old Jul 17, 2007 | 08:16 PM
SClean4's Avatar
SClean4
I've read in the Official Wheel & Tire Fitment Guide for SC300/SC400 that +38mm and higher offset will fit fine with no fender modifications needed. Get wheels with lug patterns 5 x 114.3 or 5 x 4.50.
Old Jul 17, 2007 | 10:08 PM
Blizzy's Avatar
Blizzy
I had 275/30/19's in the rear at a +40 offset and I rubbed with passengers in the rear and/or on big bumps until I rolled the fenders. Had I ran 285's or 295's, I would have rubbed much worse.
+38 is a decent rule of thumb, but tire selection has a significant role on whether you will rub. Had I got my 275/30/19's in Dunlop Direzzas, I would have not rubbed.
Old Jul 18, 2007 | 03:25 AM
ramblux's Avatar
ramblux
You could get adapters no problem, but since you would have to run at least 25mm thick adapters (to be on the safe side) the wheels would probably end up sticking out past the fenders.
And offsets are completely dependent on wheel width. +38mm on a 9.5-inch wide wheel is completely different than +38mm on a 8.5-inch wide wheel.
Old Jul 19, 2007 | 12:13 AM
SClean4's Avatar
SClean4
Thanks for the info. I'm trying to get some BBS LM wheels (or nice replicas) and have been researching all about tire size and offset recently so as to not have any problems (other than wheel gap). Any other tires that are good that won't rub much/any?
Old Jul 19, 2007 | 12:18 AM
SClean4's Avatar
SClean4
Anyone know how low or high of an offset you can go with 8.5", 9.0", 9.5", 10", etc. without rubbing on the SC300/400? Thanks.
Old Jul 19, 2007 | 12:21 AM
xx69xx's Avatar
xx69xx
yea .The guy i was gonna buy it off didnt know the offset.I Was afraid that with an adapter and such it would make the wheel stick out and rub.I'm not gonna risk it.I decided to go with my drop firs then rims.
Old Jul 19, 2007 | 05:27 AM
Blizzy's Avatar
Blizzy
This is a much better decision.
dnizzle
IS F (2008-2014)
May 29, 2015 11:35 PM
Dexterr
Mar 19, 2012 03:20 PM
ahnjae
Feb 5, 2010 10:00 PM
BLACKPIG99
Wheels, Tires & Brakes Forum
Mar 12, 2006 09:11 AM
Blackmarket
Apr 5, 2004 05:46 PM
