Speedometer Failure After Clutch Change
Old May 1, 2007 | 06:38 PM
JspecSC3's Avatar
JspecSC3
Default Speedometer Failure After Clutch Change
Alright so I just did a recent clutch change on my 1993 5speed SC300. It was a success. However, my speedometer will not work now. I know what you might be thinking. Is the speed sensor unplugged? Nope! I checked it today and it is very snug and connected. Im pretty sure I connected everything I needed to connect when I took the transmission off. There are only two plugs on the 5speed transmission. Anyway Ive searched this topic up and got no real answers. Is there anything else I should look for? Im thinking it might have gone bad after I let my transmission fall off the jack when I was removing it. Anyway please let me know. I dont know how fast Im going and I cant tell how many miles I put on my car because the trip meter stays at 0 miles.
Old May 1, 2007 | 08:41 PM
5sp_jzz30's Avatar
5sp_jzz30
well you know that at 40mph in 4th gear your at 2000rpm. at 3300rpm in 5th your are doing 80mph so figure it out...lol. 6300rpm in 5th is 145mph. as far as how many miles you have driven. the car probably gets 20mpg so when you gas up 10 gallons you know you can roughly drive 200 miles on it.
as far as the speedometer i dont know. i did my clutch a few months back also and had no problems. the gears inside the trans for the speed sensor are plastic. they may have been damaged. take out the speed sensor and check the gear.
Old May 1, 2007 | 08:45 PM
JspecSC3's Avatar
JspecSC3
I race the car so I cant do any guessing. But yeah I'll check out that sensor. I hope I didnt break it.
Old May 2, 2007 | 02:36 PM
JspecSC3's Avatar
JspecSC3
Has anyone else ever had to deal with this issue before?
Old May 3, 2007 | 12:51 AM
Sc dRifta's Avatar
Sc dRifta
*****Do not buy from this member until further notice *****
most likly damaged speed sensor or short in teh speed sensor electrical cables
Old May 3, 2007 | 03:45 PM
JspecSC3's Avatar
JspecSC3
a short??
Curtis4661
Apr 29, 2019 05:52 AM
M6nightrid
Dec 1, 2016 11:36 AM
SC300_704
Jul 22, 2012 07:53 PM
PandaSC300
Jun 1, 2005 02:48 AM
Lvangundy
Maintenance
Mar 18, 2002 09:13 AM
