Grinding noise?
Old Apr 27, 2019 | 08:57 PM
Curtis4661's Avatar
Curtis4661
Default Grinding noise?
I have a 1991 Toyota Soarer (Lexus sc300) with the 1jz twin turbo and manual transmission. When I got the car it had a bad clutch so I just replaced the clutch, flywheel, pressure plate, throwout bearing, clutch fork, and slave cylinder. When I got it all back together and started driving it, I noticed that the clutch was really soft, and it was hard to get it gear. While driving there is intermittent extreme grinding noises that I believe are coming from the transmission. I was thinking maybe because the slave needs bled and the transmission isn't going into gear completely? I honestly have no idea what it could be. There's no metal shavings in the transmission fluid and I changed it with the redline mt90 which I've heard good things about for the r154. Does anyone know what this could be?
Old Apr 28, 2019 | 03:00 AM
KahnBB6's Avatar
KahnBB6
1) Yes to Redline MT-90. That is the only oil you should use in your R154 transmission.
2) Yes, re-bleed your clutch hydraulic system to be safe. And if there is any issue with the slave or master, replace. But you will know if one of those actually goes out-- your pedal would go to the floor.
3) Is the transmission very easy and smooth to go into gear when the engine is off but very difficult to go into gear when the engine is on?
4) What brand and specific model clutch kit did you get to install into your Soarer?
5) Do you notice grinding in only one or more particular gears or at particular vehicle speeds or do you notice grinding in pretty much every gear no matter what speed you are going?
Old Apr 28, 2019 | 07:43 AM
Curtis4661's Avatar
Curtis4661
Yes, the transmission goes into gear nicely when the car is not running. The clutch kit I used was from driftmotion with an OEM pressure plate, clutch disc, and slave cylinder. The flywheel I bought from drift motion was a lightened one. The grind I'm hearing isn't linked to a specific gear it just happens every couple mintues regardless of what gear I'm in. I've noticed that if I let off the gas the grind will go away, and them I can start giving it gas again and the grind will still be gone.
Old Apr 29, 2019 | 05:52 AM
scsexy's Avatar
scsexy
check your drive shaft isnt rubbing the transmission from the flange on the slip yoke
M6nightrid
Dec 1, 2016 11:36 AM
blisiono
SC400 / 300 Classifieds
Oct 7, 2014 08:28 PM
SC300_704
Jul 22, 2012 07:53 PM
want sc300
Jan 8, 2008 06:50 PM
ScTHREE
Aug 24, 2006 12:28 AM
