gs400v8 vs TT2jz
I need help on a decision, I am trying to decide which is cheaper and easier and quicker to get me to 500rwh.. The gs400 1uz engine swap into my 5 speed sc300 with the adapter plate or the TT2jz intot he sc300? I am trying to do one of them within the next month and also need an installer in NY.. ANy feed back is appreciated,
Thanks.
Curtis
Thanks.
Curtis
I agree though. Forget the V8 unless you want the wow factor and low end grunt. Without boost, the V8 barely breaks 275whp if modded.
I found a heap v8 for 175 and the adapter plate so i thought it would be easy. I have 217000 miles on my engine so i was looking to swap it out before i thought about boosting it. i only have a $2000 budget right now so i need the best bang fro buck. I am trying to get to 350whp now.
Geez-- The SC is sooooo tight, it's almost better just to get another $500 and get a full a/t soarer 1j clip, or get another grand saved and get the full m/t soarer 2.5tt clip with the r154-- MUCH better--
The complete setup is designed to fit the engine bay and work properly and dependably-- WITH tons of aftermarket support--
I'm not sure what the stock twins can do on a 1J but 14psi should get you 350whp with good exhaust if not a little more power on a good fuel tune--
AND-- the motor is built to turbo-- the head gasket is good for 20psi stock, the pistons, rods, etc. are all built for turbo oem-- hard to beat--
It's just plain cheaper as all the factory parts are there save pedals and a few odd parts to swap from a/t to m/t ---
I wouldnt know why you would want a gs4 motor
