diy shocks
Old Mar 15, 2007 | 12:07 PM
t70 supra's Avatar
t70 supra
Default diy shocks
i have been letting my baby sit for almost a hlaf a year since my lil drift-a-bender with a fence and dodging a house. but is getting warm up here and how easy is it to swap out the shock for tokico luminas. i can do by ouwn brakes but how do i bleed the line
Old Mar 15, 2007 | 07:13 PM
Sc400Red95's Avatar
Sc400Red95
install the line on the chassis. Then let the line start to drip, Then attach the line to the caliper. Then bleed the whole system the old way. Pump 4+times at the pedal and open the bleed screw on the caliper. DO that to every corner. If you have a 4 piston caliper with 2 bleed screw you have to do it 4 times per bleed screw.
Old Mar 15, 2007 | 08:06 PM
sliva001's Avatar
sliva001
I did not have to take out my brake lines when I installed my shocks...
do the one man brake bleeding method.
install a line of the bleed valve
keep the bleed valve open
submerge the line in brake fluid bottle
pump
its kinda tricky thou.
Old Mar 15, 2007 | 08:21 PM
slammedTT's Avatar
slammedTT
he is asking how easy it is to install shocks, and he is going to do his brakes BUT needs know how to bleed the brakes.
are you just changing brake pads though? or rotors too? calipers?
Old Mar 16, 2007 | 05:47 AM
garethr's Avatar
garethr
http://web.ace.net.au/soarer/bleeding_flushing.html
Wrap the gladwrap around one end of the tubing and hold in place with the rubber band to make a simple one-way valve. This makeshift valve will let the fluid out, then collapse and stop the fluid being sucked back up again. This saves you from the traditional method of needing two people to do the job and trying to stay co-ordinated.
Old Mar 16, 2007 | 05:56 AM
T0ked's Avatar
T0ked
That's very simple and pretty ingenious.
Old Mar 16, 2007 | 07:05 AM
XxSC400xX's Avatar
XxSC400xX
That is a pretty good idea. Also I personally use ATE Super Blue brake fluid. It's blue so the color difference makes it easier to tell when you have pumped out all the old brake fluid.
Old Mar 16, 2007 | 09:46 AM
t70 supra's Avatar
t70 supra
yes that is what i am asking is it hard to swap out the shocks and bleed the brakes also i am installing new pads and brake rotors
Old Mar 19, 2007 | 09:29 AM
vwynn's Avatar
vwynn
wow that hose idea rocks!... to bad i didnt know of this when i was bleeding the breaks.. took me awhile to do all 4 sides.
Old Mar 21, 2007 | 11:21 PM
JspecSC3's Avatar
JspecSC3
It is a great idea. I usually just let it squirt onto a piece of cardboard on the floor. But this seems like much better idea. Also, removing the brake lines arent necessary when replacing the shock.
GS4_Fiend
Suspension and Brakes
28
Jan 27, 2016 12:57 PM
costanza
Maintenance
Aug 17, 2010 03:16 PM
Bobby206
Jul 11, 2010 01:12 PM
Lazy
Jan 21, 2009 04:53 AM
clivej
Apr 29, 2004 07:37 AM
