xerd headers :(
Old Mar 8, 2007 | 09:39 AM
97-SC300's Avatar
97-SC300
Default xerd headers :( VIDEO
i recentry installed xerd headers on my sc300, and i am getting this anoying buzzing or like a rattling sound at right about 2500RPM, i know i dont have any leaks because i checked all over, even wrapped the bottom where the header meets the pipe with high temp exhaust foil type material which made a great seal. when i was installing it i used hi temp silicone on the gaskets, because kevip from MVP recommended it. anyways anyone on here have this issue? or does anyone know how to correct it. or maybe its just how its supposed to sound.
Old Mar 8, 2007 | 11:36 AM
Sc400Red95's Avatar
Sc400Red95
is the rattling coming from the engine bay... or some where else in the exhaust system. If it's not from the engine bay look near the rear section of the exhaust layout. After the main cat there is a clamped on heat shield. Mine is starting to rattle. But if it's from the engine bay, some noise comes with the new headers. Because they are thinner so more noise goes by.
Old Mar 8, 2007 | 12:26 PM
97-SC300's Avatar
97-SC300
it sounds like its coming from the engine bay towards the bottom of the headers
Old Mar 8, 2007 | 12:36 PM
aliga's Avatar
aliga
Former Sponsor
your exhaust(downpipe) may have come off the tranny exhaust bracket.
Old Mar 8, 2007 | 01:17 PM
97-SC300's Avatar
97-SC300
i actuaaly removed that bracket completely, could that be why i am getting this sound
Old Mar 8, 2007 | 01:20 PM
94lex83457's Avatar
94lex83457
i don't have anything to contribute in terms of your noise, but can you post a sound clip?
Old Mar 8, 2007 | 01:25 PM
aliga's Avatar
aliga
Former Sponsor
your exhaust might be hitting the tranny, causeiong the noise.
Old Mar 8, 2007 | 01:47 PM
97-SC300's Avatar
97-SC300
i just made a quick video clip, you can kind of hear it later on in the video but my camera sux so, i also checked if its hitting the trans and there is no way its like 3 inches apart and its solid nothign si moving when i tryed pushing on it. can someone tell me how to resize this clip its like 1.5 minutes long and its like 93mb so its to big.
Old Mar 8, 2007 | 01:55 PM
97-SC300's Avatar
97-SC300
http://uncutvideo.aol.com/videos/ebd...063ef3?index=0
Old Mar 8, 2007 | 03:01 PM
97-SC300's Avatar
97-SC300
found the prblem guys, left 2 bolts loose on the manifold itself, sound pretty sweet now. so if you can close this thread or delete it, problem solved. stupid mistake by all means. if anyone wants a good HP gain get these headers, you can definatly feel the power. now taht i tightemned the bolts no more rattling at all.
Old Mar 9, 2007 | 06:20 PM
ki_soarer's Avatar
ki_soarer
did you buy the header new? what did it set you back? thanks. glad you fixed it.
Old Aug 27, 2007 | 05:06 PM
JspecSC3's Avatar
JspecSC3
Can you write up a little diagram on how you rigged up the universal O2 to the single wire factory O2?
Old Aug 27, 2007 | 08:42 PM
Zeal3's Avatar
Zeal3
how do u like the XERD headers? i was planning to by these but i was wondering if it was worth the hype.
Old Aug 27, 2007 | 10:40 PM
JspecSC3's Avatar
JspecSC3
Disregard my post. I just figured out that they sold me the OBD2 sensors instead of the OBD1 which is a 1 wire sensor.
PAVGR
Oct 10, 2018 11:38 AM
05RollaXRS
RC F (2015-present)
Jun 20, 2018 02:47 PM
Slyryan
IS F (2008-2014)
17
Jan 25, 2016 07:14 PM
Randre19
Oct 3, 2014 06:33 PM
PaulDejong
IS F (2008-2014)
May 6, 2013 08:38 AM
