Tacoma Automatic Shift Knob for SC
Hey I was wondering if anyone has tried a Tacoma shift **** for the SC. They look very similar to me. Fleabay has some afterones too that look great
I'm pretty sure they also come in Black and white. Some material needed to be removed from the inside of the shifter in order for it to slide all the way on without it making the shift/key lock get stuck. (it would be in park but the keys won't come out of the ignition. Also the hole in the black plastic bit that slides with the shifter needed to be enlarged a bit.
I bought the same one - can't get it to fit? Do you or anyone have install pics? Greg glexsc400@***.net
What part are you having problems with? The biggest issue I had was just getting the **** to slide down. The allen screw on the front of the **** needs to go in the upper hole that is on the shifter in order for it to work properly. I also had to cut down one of the spacers that came with it.
I have the Lovoc **** which I believe is the same. Everything from the set screws on the opposite side to wire instructions being unclear I just don't know where to begin. I need pictures and or hands on instruction for this application this is my new shift. http://cgi.ebay.com/ebaymotors/LEVOC...spagenameZWD1V
bmsc300
May 23, 2011 12:34 PM
Blue98Gs3
Jan 18, 2004 11:59 AM
