2jzgte converting rear end
Old Dec 3, 2006 | 12:24 AM
Duckness's Avatar
Duckness
Default 2jzgte converting rear end
i have a few questions on swaping my 2jzgte in my sc300.
im not sure whats best for daily driving (and maybe going
single turbo later on) either go for tt auto lsd
rear end or just keep the stock rear
and get the TRD auto lsd.
what are the differences as in gas mileage
and i know the gear ratios will be differet.
i just want to know the pro's and con's.
thanks for the help.
Old Dec 3, 2006 | 12:48 PM
Duckness's Avatar
Duckness
need help!
Old Dec 3, 2006 | 12:53 PM
Jarrett H's Avatar
Jarrett H
I was pretty sure the TT auto had like a 3.71 rear end or somthing similar. Its ideal for a performance auto platform with street driveability. I think its also larger then the sc's rear end and holds more power. Grab a used auto diff and put that in. If you ever decide to change the gears or get a different lsd, you will have soo many different choices with the TT setup.
Old Dec 3, 2006 | 02:13 PM
Duckness's Avatar
Duckness
im having problem locating a tt auto lsd rear end so i was just weighing
my choices. i know the tt rear end pumpkin is larger then the stock sc300.
the tt auto has a 3.76 ratio and the stock sc300 is 4.2 something ratio.
i was gonna run the stock rear end with TRD lsd so i just want to know how
well that works and driveablity and gas consumption.
what do you think i should do?
Old Dec 3, 2006 | 02:51 PM
TurboB6's Avatar
TurboB6
It might be easier replacing your diff and ring gear then locating a complete auto tt rear end.
The auto tt carrier housing is the same size as the auto sc300. The 6spd carrier is larger though.
Old Dec 3, 2006 | 06:36 PM
Duckness's Avatar
Duckness
where would i go about getting those parts? and price?
appreciate it.
Old Dec 3, 2006 | 09:42 PM
TurboB6's Avatar
TurboB6
appreciate it.
Most obvious question is whats your budget? Are you looking for a stock auto tt diff or trd unit? The ring and pinion can be bought from the dealer. Not sure on price since I've not replaced one yet.
Old Dec 3, 2006 | 10:27 PM
Duckness's Avatar
Duckness
yea im looking for a stock auto tt rear end with lsd is what i really want with that gear ratio to fit my swap. the trd runs around 900 but then id have the stock sc300 gear ratio which i dont really want.
Old Dec 5, 2006 | 05:42 PM
Duckness's Avatar
Duckness
anyone running the DaveH lsd unit? how's that compare to the trd lsd?
also i heard the stock sc300 gear ratio is good for drag racing with trd lsd but sacrificing top end speed.
whats the majority 2jzgte swap using?
scsexy
SC400 / 300 Classifieds
Mar 11, 2017 08:53 PM
Blk97SC300
Nov 3, 2016 10:16 PM
chrisacura
Jan 24, 2010 03:11 AM
99Aristo
Dec 8, 2007 07:42 PM
JoshFSM
Apr 16, 2006 08:00 AM
