Cheapest way to replace o2 sensor
Old Aug 9, 2006 | 12:12 PM
martshap's Avatar
martshap
Default Cheapest way to replace o2 sensor
I am getting ready to sell my 1996 SC300 and the Check Engine Light has been on for a while, which I have been ignoring because I have been too busy to deal with it.
Anyway, yesterday I had the computer run on it and it came up with "P0135 O2 Sensor Heater Circuit Malfunction (Bank 1 Sensor 1)"
I assume this means I need to replace the O2 sensor. So what is the least expensive way to go about this?
Should I buy the part myself online and then have a mechanic install it. (I am pretty much an idiot when it comes to cars so unless it is as simple as just screwing it in I would rather pay someone to do it)?
If so: A) Where should I buy the part? B) Aftermarket or OEM? C) How much should I have to pay a mechanic to install it?
BTW, obviously I am trying to avoid going to the dealership and spending too much money.
Thanks.
Old Aug 9, 2006 | 12:51 PM
Streamline's Avatar
Streamline
o2 sensor writeup for SC300 in Maintenance section
https://www.clublexus.com/forums/sho...d.php?t=137797
Old Aug 9, 2006 | 01:17 PM
martshap's Avatar
martshap
Thanks. I had read that thread but it doesn't really answer any of my specific questions.
Old Aug 9, 2006 | 01:48 PM
aliga's Avatar
aliga
Former Sponsor
i have the sensor from a 97 sc300 with 40k miles, 50 shipped, and will take you about 30 mins to install.
Old Aug 9, 2006 | 08:23 PM
Tammy's Avatar
Tammy
A recent post referred postive to this site... OxygenSensors.com
http://www.automedicsupply.com/index.php?
Old Aug 14, 2006 | 08:59 AM
martshap's Avatar
martshap
Gazi,
Is that an OEM sensor? (I.E. Am I going to have fool around with splicing the wires in order to connect it?)
Thanks,
Marty
Old Aug 14, 2006 | 02:44 PM
chitwnsazn's Avatar
chitwnsazn
just splice it. 2min worth of your time to splice is better than spending $50 or more for an oem sensor. And make sure how many wires your O2 sensor uses. I remember the cali ones or something have 4-wires while others only have a single wire??
Old Aug 27, 2006 | 11:41 AM
philauldridge's Avatar
philauldridge
If it is just the heater circuit, then the O2 sensor itself is working fine. You could always trick it by putting a big resistor (or wiring another dead O2 sensor, with intact heater circuit) inline, but that might be a bit complicated. The sensor, at any rate, should be a plug and play, so, if you don't mind crawling under your car (just aft of downpipe), you can screw the old sensor out of the pipe, screw the new one in, and plug the wires back in.
And, yes, if yours has the heater circuitry, then it should be a 4-wire sensor, not the one-wire version.
Aportis72
Mar 11, 2019 10:14 PM
Eric00GS3
Mar 22, 2011 12:55 PM
Blaizze
Oct 3, 2008 12:37 AM
Faymester
IS - 1st Gen (2001-2005)
Jan 17, 2007 02:07 PM
tomv
RX - 1st Gen (1999-2003)
Dec 20, 2004 12:04 PM
