What O2 Sensor For P0138 & P2195
Old Mar 7, 2019 | 01:22 PM
Aportis72's Avatar
Aportis72
Default What O2 Sensor For P0138 & P2195
Hello all and thanks in advance for the help.
I am new here, but have been lurking and searching, but can’t quite figure out which O2 sensor I need to replace. Or do I need to replace both. I believe only 1 is bad, causing the other to give a bad reading, but in all my reading im not sure.
Car is a 2007 IS 250 AWD with 98825 miles. VSC and check engine came on. Scan showed
P0138 O2 sensor circuit high voltage bank 1 sensor 2
P2195 O2 sensor signal biased/stuck lean bank 1 sensor 1
Thank you.
Old Mar 7, 2019 | 01:47 PM
Gville350's Avatar
Gville350
Assuming the car has all OE O2 sensors, you might as well replace all four to maximize fuel efficiency and power output.
Old Mar 8, 2019 | 11:41 AM
Aportis72's Avatar
Aportis72
I am selling the car and only want to buy 1 instead of 4 and only want to replace 1 instead of 4.
Old Mar 11, 2019 | 08:05 PM
Aportis72's Avatar
Aportis72
Anybody???
Old Mar 11, 2019 | 10:05 PM
DennisMik's Avatar
DennisMik
P0138 is the bank 1 sensor 2 has a high voltage level for too long.
P2195 is the bank 1 sensor 1 has a high voltage level saying the exhaust is too lean.
Bank 1 is on the passenger side of the car.
Sensor 1 is the sensor closest to the exhaust manifold, also called the upstream sensor.
Sensor 2 is after the catalytic converter, also called the downstream sensor.
The sensor 1 (P02195) is probably the problem and "confusing" the sensor 2.
Old Mar 11, 2019 | 10:14 PM
primavera's Avatar
primavera
https://www.clublexus.com/forums/is-...ensor-2-a.html
mrblister
GX - 1st Gen (2003-2009)
Jul 23, 2025 03:24 PM
ADENNARD
May 21, 2013 06:27 AM
jmsmiff
Mar 27, 2013 07:28 PM
martshap
Jul 8, 2009 04:26 PM
