Transmission Sounds
Old Jul 3, 2006 | 07:36 PM
ScTHREE's Avatar
ScTHREE
Default Transmission Sounds
I have a 96 Sc300 and my clutch makes a high pitch squeaking sound everytime it engages usually only in first gear. Its a six puck clutch. Any idea what could be the problem?
Old Jul 5, 2006 | 03:46 PM
GoCarSc300's Avatar
GoCarSc300
Default Same Problem
I don't know what the problem is, but I have the same noise when I engage first gear. I also have a 6 puck clutch. It's made by RPS. What company made yours?
Old Jul 5, 2006 | 05:06 PM
ScTHREE's Avatar
ScTHREE
I have no idea what company makes the clutch because it came with the car when i bought it. My friend tells me its because the clutch is overkill for a stock setup. Did your clutch make that noise when you had a stock clutch in there? If so i think i need to switch to OEM.
Old Jul 5, 2006 | 08:07 PM
audi2nr's Avatar
audi2nr
you get a noise when u press the clutch? if so its mostlikely the throwout bearing, you did replace that when u put the new clutch in right?
Old Jul 5, 2006 | 08:27 PM
ScTHREE's Avatar
ScTHREE
no its not when i step on it its when im releasing it and its about to fully engage at the friction point.
Old Jul 5, 2006 | 10:27 PM
nimit1234's Avatar
nimit1234
haha i get it too.. never figured it out.. and it only happens when its cold and im relaeasing 1st gr.. its funny how it happens to alot of people
Old Jul 5, 2006 | 10:48 PM
ScTHREE's Avatar
ScTHREE
i wish mine only happened when it was cold then it wouldnt be so bad it happens whether it is cold medium or hot i hope this is fixable
Old Jul 6, 2006 | 12:18 AM
GoCarSc300's Avatar
GoCarSc300
Mine happens at all temperatures also. My stock clutch never made this noise and when I first installed the clutch it didn't make this noise either, but now it does when engaging first gear sometimes. I guess let us know if anyone knows what the problem is and if there's a possible fix.
Old Jul 12, 2006 | 07:11 AM
arstraub's Avatar
arstraub
Have you guys had many transmission problems w/ the sc's; 300 or 400's??
Old Jul 12, 2006 | 09:54 AM
vipsoarer's Avatar
vipsoarer
its the friction of the clutch material on the flywheel creating a resonation noise. its the same reason why high friciton material brake pads will squeal when not braking hard. I bet if all of you drop the clutch on a launch it wont make this noise... id just get used to it.
Old Aug 23, 2006 | 04:25 PM
fosterjd24's Avatar
fosterjd24
Acctually i dropped the clutch and now it makes an even worse noise. I think its time for a new clutch, time to go back to oem full disk.
Old Aug 24, 2006 | 12:28 AM
vipsoarer's Avatar
vipsoarer
one thing to check is put it in 5th gear and floor it. if the revs jump and you dont gain speed its defn time for a new one. its starting to sound like you may have glazed the clutch or whats left of it. good luck
snook
Nov 26, 2009 09:03 PM
93sc3005sp
Jan 1, 2009 01:17 PM
dinhnerz
Jul 11, 2007 12:53 AM
presponse
Dec 19, 2003 06:21 PM
hwallen172
Jan 8, 2003 01:10 AM
