really BAD idiling problem
Old Sep 25, 2001 | 02:28 PM
lxxxs's Avatar
lxxxs
Unhappy really BAD idiling problem
so what could it be? im thinking it has either to do w/ the MAF sensor or the throtle postion sensor. it never usee to be a big deal but now its really bad. it wont start if ive been driving awhile and the car is warm/hot. and when i pull up to a light to stop i have to keep the motor reving high. and today it started kinda sputering while i was driving???? it never did that before it was always fine once i got going down the road and ther was air flowing.
so am i on track w/ the MAF or am i missing something else?
i have a new MAF coming tomorrow, b/c the screen thats in it fell out.
any help guys,,PLEASE!!!!
Jc
i got more pics coming of my CARNE digital ignition and short shifter!!
yeah where did the gallerys go?
Old Sep 25, 2001 | 08:11 PM
CmputerWiz's Avatar
CmputerWiz
Short shifter....what brand?!
SR
Old Sep 26, 2001 | 04:45 AM
lxxxs's Avatar
lxxxs
the short shifter was custom.
i got the directions from someone on here,
if u would like them ill write them down again.
now what about my PROBLEM???
Old Sep 26, 2001 | 05:00 AM
ChrisK's Avatar
ChrisK
I tend to think that you are having problems with the throttle position sensor. I had to replace mine. In my case, the engine would die when going from high RPMS to idle. Also, I believe the bad MAF would cause Engine codes.
Chris K.
95 SC400
Old Sep 26, 2001 | 05:23 AM
Keith13b's Avatar
Keith13b
Is your Crane ignition already installed? I had an ignition box go bad and it had extreemely similar symptoms. I mean to a TEE! If possible, bypass the box(s) and see if symptoms persist.
Check the connections on the MAF, and test the O2 sensors.
Look for intake leaks- cracked intake snorkle, loose vac line, bad gasket, poped off hoses, etc.
Old Sep 26, 2001 | 05:37 AM
lxxxs's Avatar
lxxxs
it was doing it before i had the CRANE installed. the ignition actually helped a little it gave it more spark when it would idle low.
ok i think ill go ahead and order a throttle position sensor as well.
but please dont stop with ur thoughts on what the problem is im still not sure.
thnx guys
Jc
Old Sep 26, 2001 | 02:29 PM
mkmbt's Avatar
mkmbt
I had an intermittent problem with my idle a few months ago. The car would have difficulty maintaining an idle and when I attempted to accelerate, the engine would simply sputter and I would barely move forward. Sometimes the engine would not start or the engine would sputter out and die. It would happen at anytime, but seemed more prone to trouble when it was hot or had just been running. It turned out to be a bad fuel pump. the fuel pump was replaced and I have not had any problems since.
Good luck.
Old Sep 27, 2001 | 04:23 AM
lxxxs's Avatar
lxxxs
thanx, there is something elese i will look into. but it doesnt sputter off the line. it is just when it is sitting still like at a light. and i can stop it from shutting off, if i keep my foot on the gas and keep the revs up to around 2k, it sputters while its up there , but it doesnt die.
i also had someone tap the MAF housing while ther car was idiling and it would make the car idle right for a few seconds.
is there any way to tell if its bad for sure like a diagnostic test at lexus or anything like that, where they could hook it up to there machines.
thanx again guys
Jc
Old Sep 27, 2001 | 06:30 PM
933005spd's Avatar
933005spd
Post check with vom
I'll check later, there is a test procedure in the manual.
You do have the lexus manual? Right?
I suggest to all to get these, go and order from your dealers. Great resource with two volumes.
Old Sep 28, 2001 | 07:03 AM
lxxxs's Avatar
lxxxs
well i got my new MAF in last night put it on took the battery off for 20min to reset the computer. and ...............
it di not a f#$%^&@#@ing thing!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
so i finally beged the dealer to look at in on next wed. they didnt want to even look at it at first, but then i told them i would pay for them to jsut look at it and not to fix it they said OK.
they are such ******, sometimes but the they have the equipment right.
ill let u know what they found.
Jc
t2d2
Jun 27, 2014 06:34 AM
lexus-is2
Mar 26, 2013 07:12 PM
1993Ls400s
13
Oct 2, 2008 12:36 PM
animefreak
12
May 16, 2008 12:30 PM
