Supra rear brake install help!
Old Nov 8, 2005 | 12:20 AM
FCDRIFT's Avatar
FCDRIFT
Unhappy Supra rear brake install help!
hey guys, im pretty new here and im trying to install some supra brakes on my sc3. i got the front ones on fine, but the rears is where im having some trouble.
i got as far as taking off the stock caliper, bracket, and rotor. when i tried to put the supra rotor on, it hits the inside drum brakes for the e-brake. i tried to adjust the brakes a bit but even at the tightest setting, still the rotor would not fit on. i took it back out and measured the stock one compared to the turbo one. the stock ones have a bigger inside diameter for the e-brake than the turbo ones. is this normal? or did i get the wrong rotors?
has anyone done this swap before and can help me out? any input will be greatly appreciated.
Old Nov 8, 2005 | 04:31 PM
Minuet's Avatar
Minuet
Hmm.
I just did mine last week and the new Turbo rotors fit like a dream.
You must have the wrong rotors.?
Take a look.
Supra TT rear on my SC3
Stock 97 rear rotor next to a rear 97' TT
Old Nov 8, 2005 | 10:34 PM
FCDRIFT's Avatar
FCDRIFT
what is the difference between the 92 rear supra rotor and the 97 rear rotor? maybe i got the wrong year, is there a difference?
Old Nov 9, 2005 | 04:40 AM
YZFR1's Avatar
YZFR1
There's the problem. You need a 93.5+ supra part from the MKIV supras.
Old Nov 9, 2005 | 07:40 PM
FCDRIFT's Avatar
FCDRIFT
oh, so there IS a difference between the newer and older supra models. hence the different stock numbers?
Old Nov 9, 2005 | 07:41 PM
YZFR1's Avatar
YZFR1
Well.............. yes........................
Old Nov 10, 2005 | 05:00 AM
aliga's Avatar
aliga
Former Sponsor
mk3 is not equal to mk4
Old Nov 11, 2005 | 12:22 AM
FCDRIFT's Avatar
FCDRIFT
well the rotors that i bought were for a 96 supra tt. but my car is a 92 sc. so should i get the rotors for a 93.5? thanks for the great info guys!
Old Nov 11, 2005 | 06:49 AM
YZFR1's Avatar
YZFR1
The rotors will be fine.... Any 93.5+ supra tt will fit............ now you need Calipers though.
Old Nov 11, 2005 | 08:26 AM
vipsoarer's Avatar
vipsoarer
id run the part numbers across with someone to double check to see if they sent you the correct ones or not
Boostshakalaka
Jan 16, 2004 12:18 AM
Mischievious GS
Suspension and Brakes
Jul 24, 2003 12:27 AM
SpdRcr0
Nov 11, 2002 05:03 AM
DeniskaGS4
Jan 25, 2002 05:58 AM
gadgetSC
Apr 23, 2001 04:52 PM
