Fixing a warm start problem
I've been having a lot of trouble with my 1994 SC400 on warm starts. I bought this car a few months back when it (unknownst to me) had this problem. Since then I have spent of the order of 2 grand trying to fix it (at the local lexus mechanic). I know I've been paying top dollar for my repairs, but I was hoping that they knew what they were doing. I'm fast starting to lose faith
. After my fourth trip to Lexus it reared its ugly head again today. The basic symptoms are (it seems) after driving the car for a while (30-60 mins) and stopping it such that it's still warm (30-120mins) when I turn the car over it chugs and dies (perhaps as if starved of fuel). After trying to start 3 or 4 times it will finally start up. On the bad starts flooring the throttle does nothing and the engine always just seems to cut out (chug chug chug, die). I've noticed the faint smell of something when this happens too, perhaps a slight petroly smell. It's a nasty intermittent problem that's very hard to show a tech.
In an attempt to fix i've had:
- The throttle position sensor replaced.
- The idle air control motor replaced (diagnosed by a lexus tech as the problem). This seemed to work for a while, but a couple of weeks after they replaced it a check engine light came on and I took it back and they said it had a bad connection. Since then the warm start problem has been getting bad again. (Could it be a bad part? -- it's new). I don't seem to have any variance in idle RPM.
- A faulty O2 sensor replaced (about a week after it got back from the Air flow meter jig, the check engine light came on again and apparently this time it was my O2 sensor).
I also had the EGR plates on my motor replaced (unrelated) because apparently they were missing (and it passed smog?).
After cruising the forums the problem seems as if it could be the FP ECU. This is probably the next thing I take a look at (after I call up Lexus and whinge tomorrow). By the sounds I can probably replace it myself (without paying hundreds of dollars labor)?
Does this sound like a reasonable avenue to persue? Anything I (or the well paid lexus mechanics) could be overlooking? Any help would be very much appreciated (between this and the whining differential the SC400 is starting to drive me insane).
t.
I'll make sure to post when I finally manage to fix this issue (and my weird differential whining). The most painful aspect is the $900 idle air motor. I guess my O2 sensor probably went, and the TPS was probably bad too)
t.
(And for search system optimization purposes I'll just make sure to mention: warm start and starting problems, fuel pump ECU, fuel starvation, engine cut out, idle air control, IAC, stealing dealers )
Now that I've got the old one out is there anyway I can test it to determine if it's bad? Or is there any way I can tell whether it's old? I only bought this car recently and the one I took out looks *exactly* the same as the one I put in. Are there serial numbers or model revisions since 1994?
I immediately noticed the car driving quicker and having lower idle RPMs (which seems a little weird). Perhaps that's just a side effect of having disconnected the battery (and maybe resetting another ECU)?
t.
I agree with the frustration of incomplete posts on fixes... the questions keep coming, but sometime the solutions don't get followed up...BUT!! This is still the best site to get answers..so mods don't lock me out
Now if only the whine I get at 20 and 45 mph on cold mornings would go away. The lexus mechanics swapped my diff out, but now that the weather is cold it's started up again.
Aaargh!
t.
Garage on second attempt wanted $800 parts and labor for the IAC. While I was thinking about it, did some research here. Spent $100 at a junk yard for the ECU and installed myself.
92 sc400
