SC400 Engine Noise
Old Feb 8, 2005 | 02:27 PM
Fastfwd's Avatar
Fastfwd
Default SC400 Engine Noise
My SC400 is starting to have a noise when in gear at idle. It has sounded to me like a bearing going out and when I described it to a mechanic he said it sounded like the cam belt tensioners (?) bearings. Does this sound right? This guy had a Testarossa out front of his shop. He does all the hot foreign cars around here. I think he knows what's up. I'd like to hear from the experts here what it could be. I don't see any mentions of any sort of engine problems as typical (only valve adjustment). I have neglected the oil changes a bit, but not really bad and I really don't rag on this car all the time. He said this is the normal maintenance for this engine at this mileage. What do you guys think?
I can make a video of the noise maybe and share it to give a better idea. It doesn't do it all the time. Only occasionally, but I'm sure it's going to get worse. Any ideas on costs? Any guides on DIY for this if that's what it is? I've got more time than money.
Old Feb 8, 2005 | 09:00 PM
PERRYinLA's Avatar
PERRYinLA
I may have the same noise. It's a high-pitched squeeking/worn bearing sort of noise and only happens when the car is in gear (if I put it in neutral, it goes away). And it is not too loud- I only hear it when the car is near a wall and I have my window down, so it reflects off the wall and bounces into the open window.
Such a scenario only happens in the drive-thru lane, so if it wasn't for my addiction to In-and-Out burgers, I may have never noticed it.
Old Feb 8, 2005 | 09:52 PM
Fastfwd's Avatar
Fastfwd
My noise is more of a low clacking (?) sound. I can feel it too. It doesn't sound real pretty. I do think it could be a bearing though.
Old Feb 8, 2005 | 10:35 PM
PERRYinLA's Avatar
PERRYinLA
Oh, we may not have the same issue, then- I certainly don't feel mine.
Jefe's IS
Jan 5, 2009 07:40 PM
sjgIS350
May 5, 2008 10:51 AM
LexXxuS101
Oct 10, 2007 11:14 AM
LEXBOGGY
Dec 15, 2002 04:09 PM
Juan C. Cos
Jan 14, 2002 08:32 PM
