The beast has awoken
Subscribe
Feb 20, 2004 | 06:33 PM
is all i can say...
I redid a lot of vacuum lines on my car over the past few weeks and actually now have my wastegate signal plumbed directly from the compressor housing on the turbo; this revealed a serious problem; my wastegate spring has gotten really saggy... it went from 6psi, to 4psi when i redid all the vacuum lines; and then to 2-3psi when i plumbed the wg signal; the spring was SUPPOSED to be a .4 bar
it was a serious letdown driving the car around when its only a little faster than stock; the car would open the wastegate at half throttle and it'd get loud as HELL
Today I installed a boost controller.... and now i'm running 8psi in 1st, 9psi in 2nd and 10psi in 3rd with no knock... i've got ignition dialed back 2 degrees from base timing
WOW; the car is EVIL EVIL now; and right around 7psi which i've never hit before it makes a really loud whistling spool sound; and at 10psi its making a turbine scream; its awsome
i scared the **** out of someone today when they were turning and i went by lol
whats weird though is after redoing all the vacuum lines and stuff; my blow off valve isnt NEARLY as loud as it used to be... very odd i think... it still blows off; its just quieter... no compressor surge or anything like that
Reply 0
Feb 20, 2004 | 07:58 PM
Cool
Reply 0
Feb 20, 2004 | 09:14 PM
what a rush
Man I wish I could go for a ride, it sounds off the rockers fast too
Reply 0
Feb 20, 2004 | 09:37 PM
hey bean did you try tightening the screw/**** on the bov?
Reply 0
Feb 20, 2004 | 10:17 PM
VIDEO!
Reply 0
Feb 20, 2004 | 10:34 PM
its as loose as it can get; the Turbo XS Type-H uses washers to tighten the spring inside (its a piston-based valve)
ran a 350z convertible tonight from a 2nd gear rollon... had 4-5 cars on him through 3rd...
Reply 0
Feb 20, 2004 | 11:29 PM
bean correct me if i'm wrong but aren't you suppose to tighten it instead of loosen?
Reply 0
Feb 21, 2004 | 06:43 AM
When I go to a clublexus meet, someone with an SC300 turbo is going to give me a ride, period.
Reply 0
Feb 21, 2004 | 07:19 AM
Quote:
I know Gazi in Queens has a turbo 300. I'm in line too
Reply 0
Feb 21, 2004 | 10:45 AM
Congrats man!!!
Reply 0
Feb 21, 2004 | 10:46 PM
Awesome. My turbo SC3 is also alive and coming home soon... its been gone for almost 4 months now... its all worth it though, its been in the shop throughout the winter. Coming out just in time for some nicer weather.
Kevin
Reply 0
Feb 22, 2004 | 02:44 PM
Ah...everybody's getting their NA-T's on the road for spring and mine is down for more work again .
Bean...glad to hear it's running well.
Reply 0
Feb 22, 2004 | 02:47 PM
There's nothing else like it!
Reply 0
Feb 22, 2004 | 03:46 PM
LL, what happened?
Reply 0
Feb 23, 2004 | 01:40 PM
Quote:
Kevin
Check the forcast... we have snow coming our way.
Chris
Reply 0
Subscribe
