Operating windows with engine off
Old Jul 15, 2019 | 07:56 AM
KKoll's Avatar
KKoll
Default Operating windows with engine off
Is there a way to raise / lower the windows without starting the engine? It seems like they should function in accessory mode just like my older RX with a key starter. In hot weather I like to leave my windows down during the day and raise them when the weather cools in the evening. As is I have to start the engine to perform the operation. 5 second cold starts 2X per day can't be good over the life of the car.
Old Jul 15, 2019 | 08:21 AM
Cocal's Avatar
Cocal
No all you have too do is press the start button twice (don't step on the brake pedal) and you'll be able to operate the windows.
Old Jul 15, 2019 | 08:43 AM
KKoll's Avatar
KKoll
Thank You!
Old Jul 15, 2019 | 11:57 AM
RGSW's Avatar
RGSW
Then, after adjusting the windows, press the start button again (without foot on brake) to turn the ignition system to "OFF".
Old Jul 15, 2019 | 02:47 PM
kolokmee's Avatar
kolokmee
You can also get your dealer to program your car so that you can open and close all the windows just by using your key.
Old Jul 15, 2019 | 02:54 PM
Cocal's Avatar
Cocal
That should already be programmed as it is the default.
Old Jul 15, 2019 | 03:02 PM
kolokmee's Avatar
kolokmee
Thought the default was Off? I had to get my dealer to program the '16 to allow my key to close all the windows (and sunroof) from outside. Never tried the all-window open remote fob though.
Old Jul 15, 2019 | 05:45 PM
mspearl95's Avatar
mspearl95
every lexus I've had, I've had to have the dealer enable this function.
Old Jul 15, 2019 | 10:19 PM
Nail34's Avatar
Nail34
Programmable by dealer only:
□ Turning the key right and holding the position for 2 seconds will not close the windows and moon roof (Standard) = Off
□ Turning the key right and holding the position for 2 seconds will close the windows and moon roof = On
□ Turning the key left and holding the position for 2 seconds will not open the windows and moon roof (Standard) = Off
□ Turning the key left and holding the position for 2 seconds will open the windows and moon roof = On
Old Jul 16, 2019 | 05:38 AM
Cocal's Avatar
Cocal
I got my 2017 with this operating, I Think it's part of the PDI and original set-up, obviously some dealers don't do it and wait for a complaint to activate it.
The reason why I said that I think this is part of the PDI is because all of my previous vehicles (different makes) had this feature without me asking for it.
Old Jul 16, 2019 | 09:40 AM
mcomer's Avatar
mcomer
pre-2010 models (with fixed key fob) had the remote window rolldown defaulted On.
2010 and newer (with hidden key fob) had the RWR defaulted Off.
Old Jul 16, 2019 | 03:40 PM
OoAaronoO's Avatar
OoAaronoO
I was gonna say I knew my is had it default...damn windows went down and it stormed outside. Like a pool in the car 😔
Old Nov 10, 2021 | 06:16 PM
PhxBill's Avatar
PhxBill
Default Can Enform roll up the windows?
2021 model. I know I can lock the doors, but can the app close the windows? This is Phoenix and even in the fall I leave the windows down a little in the day but would like to close them at night. Didn’t see anything obvious in the app.
Old Nov 11, 2021 | 10:30 AM
mcomer's Avatar
mcomer
Lexus cars have an Anti-Jam feature for the windows and sunroof. If you actuate the window switch
and release it the window or sunroof will stop and reverse a bit if obstructed. If you actuate and hold
the switch it will override the Anti-Jam and continue to close.
The Remote Window Roll Down will open all the windows and the sunroof remotely when you press
and hold the fob unlock button. There is No setting to permit the fob to remotely close the windows
because you might be out of sight and by holding the (remote) button you could close the window on
a child's head or dog paw.
Using the mechanical key from the fob in the Driver's door lock cylinder and turning it counter clockwise
will close the openings and because you are right there you should be able to see even the far side windows.
This feature works but is awkward for cars such as the 2016 and newer RX's that cover the lock cylinder.
jimmyjazz
Dec 4, 2020 03:49 PM
shreddog
Jan 8, 2014 10:04 AM
grottoman
Dec 10, 2012 09:11 PM
Madsci625
Aug 2, 2010 09:40 AM
