Replacing wiper blades?
Old Mar 18, 2024 | 04:24 AM
  #226
Quantum501's Avatar
Quantum501
Originally Posted by AustinTex
I went to replace my wiper blades and realized the attachment on the wiper blades does not fit the new blades I purchased from a box store.
looking online it looks like one option is to buy OEM inserts and replace just the inserts
what is the recommended replacement method? Should I have purchased I different type of blade?
I just do the OEM inserts. Super easy and cost is much less than the full blade replacement. OEM fits the curve of the glass perfectly. I only do maybe every couple of years
Viktor did a video with part numbers and full procedure.
Old Mar 21, 2024 | 04:54 PM
  #227
AustinTex's Avatar
AustinTex
Just replaced all three blades with the inserts from the Lexus dealership. Dealership charge $11.99 per insert.
video helped out
thanks
Old Apr 30, 2024 | 08:16 PM
  #228
Rainor's Avatar
Rainor
9th Gear
Default Wiper blade replacement 2019 Base
I read the manual and checked on Youtube but my car doesn't seem to operate the same??
When the wipers are turned off they retract unter the hood. I can't get the wipers to stay stopped in the middle of the windscreen. The instructions say to turn the engine off, then in the accessory position lift the wiper lever up for 2+ seconds and they should stop in the middle of the windscreen. This doesn't work.
Any ideas?
Thx, Rainor
Old Apr 30, 2024 | 09:37 PM
  #229
Rarebird1's Avatar
Rarebird1
Try turning them on then cutting the car off mid stride and catch em in the right position
Old Apr 30, 2024 | 11:16 PM
  #230
Rainor's Avatar
Rainor
9th Gear
Thx Rare bird but I already tried that and the Lexus is "smart" enough to return the Wipers to their home position even after the engine is stopped.
Old May 1, 2024 | 07:14 AM
  #231
ravenuer's Avatar
ravenuer
I've never had to do that, but I'm surprised the wiper motor would still have power to it with the ignition off.
Old May 1, 2024 | 08:13 AM
  #232
Randyp1234's Avatar
Randyp1234
Several things are still powered after you shut off the car until you open the door.
Old May 1, 2024 | 09:36 AM
  #233
ravenuer's Avatar
ravenuer
You're right....didn't think of that.
Old May 1, 2024 | 09:59 AM
  #234
Rainor's Avatar
Rainor
9th Gear
Duh!!!
Like my wife always tells me - READ THE INSTRUCTIONS.
So I followed the instructions and guess what - it worked.
Thanks to those who tried to help.
​​Case closed.
Rainor
Old May 1, 2024 | 10:41 AM
  #235
ravenuer's Avatar
ravenuer
Duh!!!
​​Case closed.
Rainor
I thought you did when you said you read the manual. But glad it all worked out!
Old May 1, 2024 | 11:01 AM
  #236
Rainor's Avatar
Rainor
9th Gear
You're right that is what I said. What my wife really said was "Read the instructions CAREFULLY". The devil is in the details! 😞 Another post to add to the dumbest question of the year!!
Old Aug 19, 2024 | 07:09 AM
  #237
bsekf's Avatar
bsekf
Default Rear Wiper Replacement RX350
Got the 3 blade wiper replacement kit. I can't figure out how to change the rear wiper. Book says, "Take to Dealer" , is that the only way?
Old Aug 19, 2024 | 07:36 AM
  #238
jollick's Avatar
jollick
Here is your answer.
Old Aug 19, 2024 | 07:45 AM
  #239
NotAFiat's Avatar
NotAFiat
Default Wiper Replacement
There are numerous videos on YouTube which shows this process for front and rear wipers. No need for a dealer visit. Here's just one video. At the 2 minute 20 second time Viktor shows you how to access the rear wiper.
Old Aug 19, 2024 | 09:30 AM
  #240
15RX98422's Avatar
15RX98422
good video. Thanks from me.
