Replacing wiper blades?
Old May 14, 2023 | 07:54 AM
  #196
Randyp1234's Avatar
Randyp1234
Originally Posted by Rollerdog
I was hoping someone could explain how this works. I will check the manual.
If it works like my 2019 - as soon as you shut the car off, press up on the wiper arm like you do when you want them to swipe once but hold it for a few seconds, then release. The arms should raise up and stay. If I remember correctly, when you re-start the car you have to tap the wiper arm again and they'll return to the normal position.
Edit - Quantum501 must've posted while I was typing because their reply was there when I looked.
Old May 14, 2023 | 05:53 PM
  #197
jcg0324's Avatar
jcg0324
Rollerdog, get familiar with the equipment. It is not that complicated. Read the manual and dive in. You can do it.
Old May 15, 2023 | 04:41 AM
  #198
golferjack's Avatar
golferjack
That was my point in my original message.
Old Aug 26, 2023 | 12:06 PM
  #199
nightdiff's Avatar
nightdiff
i lost the metal inserts that go on the side of the rubber blades inserts for my 2018 rx,how do i get replacements
Old Aug 26, 2023 | 02:15 PM
  #200
jcg0324's Avatar
jcg0324
You don't replace them. You will have to purchase a whole new unit. No one in their right mind loses two stainless steel strips out of nowhere.
I am sure there is more to the story.
You might try a third party like here:
Amazon Amazon
or here:
https://parts.lexusofsilverspring.co...52420E100.html
Old Aug 26, 2023 | 03:07 PM
  #201
nightdiff's Avatar
nightdiff
thx for the info , i put them in when replacing the blade inserts and now the other day the wiper was squeaking so i checked the wipers and the metal strips are gone?
Old Aug 26, 2023 | 05:21 PM
  #202
jcg0324's Avatar
jcg0324
I redid my rear wiper about a month ago and everything is working just fine. Not exactly an engineering challenge. For anyone who might have forgotten about the rear wiper I would suggest replace it once every 5 years whether you use it or not. My part number was 85214-0E050
If the part is installed correctly, there should not be any issues.
Old Aug 27, 2023 | 03:33 AM
  #203
lgb0250's Avatar
lgb0250
Veteran: Army
Just a whole lot easier for me to go to AUTOZONE when I need them and have them installed and I’m out in 10-15 mins. Do they cost more? Based on the aggravation they save me, no. I save my DIY for my toy.
Old Aug 27, 2023 | 05:04 AM
  #204
golferjack's Avatar
golferjack
You must have done something to break them. Just go to COSTCO and get a new set Who would ever take the assembly apart?
Old Aug 27, 2023 | 08:05 AM
  #205
GoldenYear's Avatar
GoldenYear
I made a dumb mistake i left the rain sensing feature on while in the car wash ,i struggled to shut off the Rain sensing too late i was at the end of car wash. Hopefully i didn't damaged the blades.
Old Aug 27, 2023 | 08:08 AM
  #206
ravenuer's Avatar
ravenuer
Well, do they still work?
Old Aug 27, 2023 | 08:15 AM
  #207
GoldenYear's Avatar
GoldenYear
Yes they do
Old Aug 27, 2023 | 08:41 AM
  #208
jcg0324's Avatar
jcg0324
The whole thing gets disassembled when replacing the rubber insert. I purchased the part from a Lexus dealer for $11.00, We are only talking about a piece of rubber here and nothing else. There is a youtube somewhere that shows how to properly place the 2 stainless steel strips when installing. This applies to my 2017 RX, yours could be different. I hope this clears up any confusion between replacing the rubber insert and the entire wiper assembly.
My intention was to replace only the rubber piece since that is the only part that gets worn out. And it will go bad even if you never use it.
Old Aug 27, 2023 | 11:44 AM
  #209
golferjack's Avatar
golferjack
Obviously it is easier and faster to just buy the whole assembly. They are very cheap
Old Aug 28, 2023 | 07:43 AM
  #210
mikemu30's Avatar
mikemu30
I use Trico OEM replacement blades and the change takes a whopping three minutes for both blades.
