Replacing wiper blades?
Old Dec 31, 2021 | 10:31 AM
  #166
jcg0324's Avatar
jcg0324
https://www.ebay.com/itm/313051435781 Here's a link to the PIAA blades I bought last March.
Old Dec 31, 2021 | 10:38 AM
  #167
PIAA silicone blades are fantastic clean them every few weeks and coat with spray wax. I'm 3+ years into a set they look like new.
Old Jan 1, 2022 | 05:40 PM
  #168
mrplesh's Avatar
mrplesh
Originally Posted by ViktorG
Hi guys, I am a Lexus Master Tech and I am working on a series of maintenance and repair videos that will cover the latest gen RX350.
Here is my fist video on how to replace the wiper refills.
Please hit me up with ideas/suggestions on what other stuff you would like to see in the future.
Thanks!
https://www.youtube.com/watch?v=MghIJdLYDbM&t
Just watched a bunch of your videos, amazingly helpful and well done! Keep up the good work!
Old Jan 2, 2022 | 04:45 PM
  #169
Jiggz858's Avatar
Jiggz858
Outstanding video for sure! Thank you.
Old May 29, 2022 | 01:58 PM
  #170
jimbosr1's Avatar
jimbosr1
Veteran: Air Force
Default Wiper blade refills
When to the dealer to get wiper blade refills and the guy says that lexus does not sell the refills anymore and the hole assembly is $60+ for the front.
I said i will order online and have done so. when the current stock runs out of refills you will have to bend over or go aftermarket. i ordered 2 sets for the front at $7.25 x 4 blades plus shipping.
You might want to get your refills while they are available!
Ordered mine from lexuspartsnow.com
Old May 30, 2022 | 10:06 AM
  #171
sderman's Avatar
sderman
Default Missing Metal Claws On the Wiper Refills - So What To Do Now?
I just tried to replace the wiper refills on my 2017 RX350. But on the original blades (yes, mine lasted this long) there is a metal "claw" that grips the end of the rubber insert on both sides locking the rubber insert and preventing it from sliding out (see picture).
My OEM insets are lacking this metal claw. So, even if I pry off the old claw to release the old inserts from the end clip, I assume that I can not use the new inserts without a new claw to hold them firmly in place. So what to do? I have my RX serviced at Toyota. Do they have claws to install the inserts properly? And why the heck did Lexus supply my replacement inserts without the claws attached?
Old May 31, 2022 | 04:12 PM
  #172
c3uo's Avatar
c3uo
Believe it or not I think they expect you to carefully remove the little metal clip and reuse it (at least that's what I've done - twice). I used needle nose pliers and a very small flat head screwdriver. It was a bit of a PITA.
Old Jun 1, 2022 | 07:06 AM
  #173
sderman's Avatar
sderman
My biggest gripe is that the instructions in the 2017 Owners Manual (pgs 603-4) do not mention the metal claw/clip. The instructions are written as if there was not a clip and that the rubber insert just slides out. I purchased the replacement inserts from an online Lexus dealer the same time I purchased the car new in 2017. I have been easily replacing the inserts myself in my ES's and RX's for more than 20 years and the wiper design without the clip has been fine. Why wait to screw us now?
Old Jun 1, 2022 | 08:14 AM
  #174
Badhobz's Avatar
Badhobz
^because 10 bucks for wiper replacements is too good for us. i just went and bought Bosch Icons instead of dealing with Lexus's b.s.
and F you lexus for going away from the J hook design on this RX... why would you bother changing something that's been working for decades.
Old Jun 2, 2022 | 04:56 AM
  #175
toyotaman7's Avatar
toyotaman7
I don't know about US, but in Canada Lexus dealers replace the wiper inserts free of charge for labor. We only pay for the refill which used to be $10 and now with the (6% official inflation rate) are $14...
Old Jun 2, 2022 | 07:25 AM
  #176
mikemu30's Avatar
mikemu30
Gosh it takes me about three minutes to swap out both blades and this style is as simple as the J hooks. Can't imagine fussing with inserts.
Old Jun 2, 2022 | 10:59 AM
  #177
sderman's Avatar
sderman
Mike, so you buy the entire blade assembly obviously already containing the rubber insert? What is the brand and part numbers for the 3 wipers you use on your 2017 RX350? I assume that your RX also originally came with the rubber insert locked onto the blade with a tiny metal claw as I described in my picture above. Thanks.
Old Jun 2, 2022 | 05:03 PM
  #178
mikemu30's Avatar
mikemu30
I use Trico Ice - they are obviously winter blades but I use them year round on both of our vehicles. A wipe of alcohol monthly and they last a year or more. The rear blade ive never replaced in five years😨
Old Jun 2, 2022 | 06:22 PM
  #179
Badhobz's Avatar
Badhobz
the problem with not having J hooks is sometimes you gotta go hunt for adapters or pay more for these special euro style connectors.
Costco sells michelin stealth wipers for 10 bucks each. Ive used them in all my lexus(s) below EXPECT for the this dang RX. WHY!? because Michelin doesnt include adapters and w/ the adapters they sit higher than oem intended ones. Had to go with these expensive Bosch Icons for no good reason (29.99 each).
WHY mess with J hooks honestly...
Old Jun 3, 2022 | 05:52 AM
  #180
mikemu30's Avatar
mikemu30
All Tricos come with the adapters ready to go - one for the J style and another for the push button for the RX. Easy Peasy.
