It seems to me that the 2017 lexus rx350 fsport has about an inch drop on the height compares to the non fsport model? Is this true or they're the same exact height?
look at the wheel gaps between the two
When you say height, do you mean the space in the wheel wells or overall height. They both list as 1760mm or 67.7 inches. The space in the wheels could be the 18" vs 20" on the Fsport. However the overall tire height is the same.
Camera angles can make it look like it's lower but I don't think the F sport is any lower than a stock RX350
All 4th Gen RX are same height! Only difference in some models are tire and wheel. 18 inch wheel has 235/65-18(tire diameter 763mm) and 20 inch has 235/55-20. (tire diameter 766mm) So if you want to be technical, RX with 235/65-18 are 1.5 mm lower.
Front spoiler lip on F Sport makes looks like it's lower.
F sport has an additional bumper lip that drips the front bumper height which might create the perception that the car is sitting lower, but I believe the height is the same.
