Beat-sonic CarPlay solution
Old Feb 10, 2020 | 05:26 AM
  #106
milk659's Avatar
milk659
Originally Posted by scsmith63
Attempting to install Beat-Sonic on my 2019 RX. The instructions sent with the kit do not match but I was able to determine where the newer cables were substituted. The problem I am having now is when I use dip switch settings 1,7 to fill the 12.3 screen the screen flickers. When I change the dip switches to 1,6 the flickering stops but it stops using the entire screen. Anyone get the kit to fill the entire screen with 5 icons on each row without flickering?
In my case the dip switch settings 1, and 6 were able to give me the entire screen display with 2 x 5 icons. Restarting your vehicle might reboot the Beatsonic device and address your issue. Best!
Old Feb 11, 2020 | 07:47 PM
  #107
Can you post a picture of your screen in the widescreen mode?
Old Feb 12, 2020 | 08:24 AM
  #108
milk659's Avatar
milk659
Here it is.
Old Feb 12, 2020 | 11:40 AM
  #109
Yeah, its stretched. Wouldnt work for me.
Old Feb 20, 2020 | 10:58 AM
  #110
critten's Avatar
critten
Ive had screen mirroring from beatsonic, and have been semi-active in this thread. The resolution is impossible to deal with on that option. Theres no fix. There are no good options without more work than necessary. Even if you can get carplay android to work, future apple updates always come out could brick the thing. I personally have given up. I am not going to sink more money for a substandard experience.I'll wait till i trade in for a 2020 or 21 lexus with carplay at this point.
Old Feb 20, 2020 | 11:14 AM
  #111
My Lsailit carplay works great. No stretching. Its a little quirky but overall its worth it.
Old Feb 20, 2020 | 01:00 PM
  #112
milk659's Avatar
milk659
Here is my experience so far.
Benefits:
1. Add Apple Carplay to 2017 RX350 for navigation apps such as Waze, Google maps; which at times surpass Lexus Navigation. Also i do not need to hold my phone to get these functionalities. Also i do not need to trade my other wise perfectly fine car. Maybe i ll step up to Gen 5, rather than a mid cycle refresh vehicle.
Cons
1. Relatively low res, and a bit of stretching.
2. The Apple Carplay interface is best suited for "touch" rather than a mouse. The Lexus mouse still tends to over shoot (which is a problem with native interface).
3. Once the unit is installed, it can either be set for Apple CarPlay or Android Auto. not both.
I feel the above mentioned benefits outweigh the above mentioned cons.
My biggest Con so far has been the installation process. The installer took way too long, and did a very poor job, and cause un-necessary problems with other parts of the car. Erik from Beatsonic tried his best to get them to correct this issue, but the installer did not work with him either. Now Lexus dealer was able to fix the issue but i have a huge bill from Lexus. Still trying to work with the Installer to get it right. My 2 cents choose your installer wisely.
Old Feb 20, 2020 | 01:08 PM
  #113
milk659's Avatar
milk659
@SW17LS Can you share a pic of your screen?
Old Mar 6, 2020 | 08:55 PM
  #114
vijayk77's Avatar
vijayk77
Default Beat sonic CarPlay Lexus RX 350
I purchased the Beatsonic CarPlay module for the 2019 RX 350 and had it installed. It works great but does anyone know how to show a full screen on the unit? It only shows a partial screen when CarPlay is activated.
Thanks,
Vijah
Old Mar 8, 2020 | 09:37 AM
  #115
jaycedog's Avatar
jaycedog
Hopefully in the next few years Lexus will focus on improving their infotainment systems. That is one department where they definitely seem to lack. If they implemented full support for CarPlay across their lines with a easy to use menu navigator, that would be greatly praised.
Old Jun 24, 2021 | 12:08 AM
  #116
KevMaster's Avatar
KevMaster
I gave up and installed this
Old Jun 24, 2021 | 07:13 AM
  #117
JSracer's Avatar
JSracer
Originally Posted by KevMaster
I gave up and installed this https://youtu.be/akdzmgMqWGM
how did the install go and how well does it function ?? any issues ??
I have had the same with wireless screen beam on the shelf for way too long uninstalled. guess i should add that to my projects list. thanks for the reminder
Old Jun 24, 2021 | 10:41 AM
  #118
KevMaster's Avatar
KevMaster
Originally Posted by JSracer
how did the install go and how does it function ??
i have had the same with wireless screen beam on the shelf for way too long uninstalled. guess i should add that to my projects list. thanks for the reminder
In response to your reply, the install was a bit tedious since you have a lot of trim to pull off then slowly remove the head unit.
But once its installed, the thing is amazing. Granted the resolution isn't perfect but it works and works well.
I've been watching the Euro 2020 while waiting on people on the car and its awesome.
Old Nov 7, 2022 | 01:52 PM
  #119
Ajmi's Avatar
Ajmi
3rd Gear
Default Same Issue
Thanks,
Vijah
Same issue here. I have used dip switch “1” as indicated in the manual and also “1” and “6” but as you can see it is not working on the full screen.
Old Nov 14, 2022 | 03:10 PM
  #120
KevMaster's Avatar
KevMaster
If I remember right there is a setting in the Lexus system for this. Look at the Beat Sonic videos. You can email them as well and they are pretty responsive
