Beat-sonic CarPlay solution
Old Apr 1, 2019 | 12:16 PM
  #76
Lepapeherm's Avatar
Lepapeherm
Talking
Originally Posted by JSracer
tried a similar setup, had similar results. i think the rca cable plug might be different
(still have to motivate to install my beatsonic with screen beam , been almost a year in the garage cabinet )
I just found out that my 3 ft AV 3.5 mm plug to 3 RCA plug male Composite Audio video cable doesn't respect the standard color code which is:
Red = Right Audio
White = Left Audio
Yellow = Video
My cable read:
Red = Video
White = Left Audio
Yellow = Right Audio
So this looks like I may be able to make this work after all, all I have to do is plug my cable correctly in the HDMI to AV box.(Interchange Red and Yellow)
I will test and keep you posted.
There may be light at the end of the tunnel!!!!! ;-)
Old Apr 3, 2019 | 11:07 AM
  #77
Lepapeherm's Avatar
Lepapeherm
Talking It is Working!
Red = Right Audio
White = Left Audio
Yellow = Video
My cable read:
Red = Video
White = Left Audio
So this looks like I may be able to make this work after all, all I have to do is plug my cable correctly in the HDMI to AV box.(Interchange Red and Yellow cables)
Finally I had the chance to do more testing ( interchanging 2 cables) and the result is positive, mirroring is working with my old Iphone 6
Did same testing with my new Iphone Xr and it also worked.
I really don't know if I'll be using it, the resolution is not really good and it is a bit distorted.
But............. I can run any application on my Iphone and display them on my car's display.
mirror Iphone 6
Resolution not satisfactory for me
Mirroring Iphone
Old Apr 3, 2019 | 11:23 AM
  #78
Lepapeherm's Avatar
Lepapeherm
My setup
Old Apr 3, 2019 | 02:29 PM
  #79
larrytrk's Avatar
larrytrk
So you just plug it to the Aux port and leave the setup in the center cubbie?
saves pulling the head unit, except won’t work in motion unless you have the Beatsonic moving
bypass, correct
Old Apr 3, 2019 | 02:31 PM
  #80
Lepapeherm's Avatar
Lepapeherm
Yes, just for testing.
I will try to relocate everything under the central console later.
Old Apr 4, 2019 | 02:49 AM
  #81
Lepapeherm's Avatar
Lepapeherm
bypass, correct
Yes, I have Beatsonic moving bypass installed, haven’t had the opportunity to try this setup on the road yet but it should work. ( Beatsonic bypass has been working with gps and video so I don’t anticipate any problem)
Old Apr 4, 2019 | 03:11 AM
  #82
JSracer's Avatar
JSracer
so you got the inmotion only from them, or the entire kit ??
i still have my full kit with screenbeam to install.
Old Apr 4, 2019 | 03:15 AM
  #83
Lepapeherm's Avatar
Lepapeherm
I only bought the Beat-Sonic NDS6223EP Navigation and DVD Control Bypass Module from them, I bought the other parts/components of Ebay.
Old Apr 4, 2019 | 09:06 AM
  #84
elimmigran's Avatar
elimmigran
Does your navigation stop tracking when the bypass module is activated? I have the VAIS because I was told it was better at the time I purchased it. Although I haven't used it, the guy mentioned to me the navi would stop tracking/mapping during the time the bypass module is activated.
I'm considering doing exactly what you did. Very simple and effective.
Old Apr 4, 2019 | 09:13 AM
  #85
Bearcat's Avatar
Bearcat
Just a shame Beatsonic never came out with a real CarPlay product like they demoed a few years ago. Wonder why it was vaporware?
Old Apr 4, 2019 | 11:00 AM
  #86
Lepapeherm's Avatar
Lepapeherm
Cool Nav stop tracking when Bypass enable
Yes, it does stop tracking but it resume about 30 seconds (looks like to me! never clocked it) after I deactivate the bypass.
It's a bit annoying because the GPS is completely lost for about 30 secondes so if you really need direction during that time you are out of luck.
Old Apr 23, 2019 | 09:13 AM
  #87
Archryhntn's Avatar
Archryhntn
Default Cell Phone Mirroring
Is there a simple device to put cell phone image onto screen for use of navigation? I do not need the full blown carplay solution discussed in the other thread.
Old Apr 25, 2019 | 12:53 PM
  #88
larrytrk's Avatar
larrytrk
Beatsonic!
Look for previous threads!
this was an answer to another thread!!
Old Apr 27, 2019 | 03:10 PM
  #89
Archryhntn's Avatar
Archryhntn
Is it true that while mirroring phone with navigation you cannot play radio or phone won’t ring through car system?
Old Apr 27, 2019 | 06:55 PM
  #90
larrytrk's Avatar
larrytrk
you must use music from cell and nav from cell, while mirroring! no car radio, may use car Map with no adjustments, on small screen.
phone comes through car.
you are in AUX mode of car, so all functions are thru phone when you use that mode
