4RX Mileage Thread
Old Feb 29, 2024 | 07:26 PM
  #436
down hill, 55-60, don't try to keep constant speed or accelerate on inclines, etc. in other words, hypermiling?
but nothing to do with ev's.
Old Feb 29, 2024 | 07:44 PM
  #437
Gdhillon's Avatar
Gdhillon
10th Gear
Originally Posted by Quantum501
I have a 2020 and mileage really depends on driving habits. On highway I get about 24 mph but in city with stop and go it drops to about 17 mpg.....sorry, I am in US so we use the goofy units. So your mileage is definitely low....about 14 mpg.
Dirty Air filter and/or MAF sensor, and old spark plugs could all also contribute. With 136k on the engine (km or miles) the plugs may be due.
ok thanks, I found a good video on YouTube for changing plugs. But having a bit of issues sourcing plugs etc, locally we only have a Toyota. Could I in theory just purchase plugs, intake manifold and throttle body gasket for a 17 highlander?
I’ve also seen guys on here recommend lexuspartsdirect.ca but shipping seems pretty high
Thanks!
Old Feb 29, 2024 | 07:46 PM
  #438
Gdhillon's Avatar
Gdhillon
10th Gear
Originally Posted by FastFord
16.5 l/100kms is a bit low for city driving...depends on how bad the stop and go, idle time, temperature, etc.
16.5 is 17 mpg (imp)
I never found eco got better gas milage, just horrible acceleration.
I get a bit better (22 RX350) in the city (14 avg) and substantially better on the highway (9.8 avg) Almost the same as my 6.2l 4x4 pick up truck!
Like Quantum501 says, check Filters, plugs, etc.
thanks for the reply
yes it does seem to shift weird/poor acceleration.
i will try off eco, it has been a bit cold here but not too crazy. I usually only idle for a few minutes
I will look into above thanks again!
Old Mar 1, 2024 | 03:06 AM
  #439
JimInTN's Avatar
JimInTN
I've gotten 28.x before in wife's RX, highest I remember.
Old Jun 30, 2024 | 04:28 PM
  #440
Desaparacedos's Avatar
Desaparacedos
I can't believe the mileage some of you guys get! I thought I drove like a total grandpa and I'm maxing out around 27 with an average closer to 25.
My theory is that the car isn't very efficient at 70-80mph (my local highway speed) but quite efficient at the 45-55mph range.
Old Jun 30, 2024 | 05:35 PM
  #441
GSFRX350's Avatar
GSFRX350
Keep in mind people maybe claiming city, highway or a mixture, not everyone states details.
I regularly get 19 mpg driving in metro areas and 29 mpg on highways, that's at 70 mph
Old Jul 8, 2024 | 10:32 PM
  #442
Lexus4rx's Avatar
Lexus4rx
The three biggest things that impact MPG are
1. The route you take
If traveling in the city, do not expect more than 22 MPG because of stop and go traffic.
2. How hard you are on the gas pedal
When your pressing more on the gas pedal, your engine needs more gas to produce more acceleration. Just apply enough to drive steady and go with flow of traffic. Avoid overtaking.
3. The wind direction
Ever rode a bike facing in direction of the wind? It's the same for a car. If traveling in the direction of the wind(10mph+) at freeway speeds, do not expect to get more than 23mpg. Engine needs more gas to produce the same speed with a headwind. You can see direction of the wind in the weather app in the infotainment panel.
With a tailwind, you can get 30+ MPG at 60MPG freeway speed. There is less wind in the evening and night time than during the day,
With the above 3 tips, I'm consistently able to average 25-28mpg on my 2017 RX 250 (with AC ON). My highest was 31MPG on a 8mile trip going to work with a tailwind.
I've found things like tire pressure (unless its below 25PSI), hyper-miling (very unsafe) and the grade of gas you use doesn't matter that much.
Old Aug 9, 2024 | 11:14 AM
  #443
Rx350driver's Avatar
Rx350driver
Default 24.5 mpg on mine.
Originally Posted by ccb777
Was checking to see what you really get on the highway in gas mileage. It states 28 mpg. I have a BMW that states 28 mpg but in highway driving I normally get about 30 mpg w/o ac running. This is by measuring mpg after filling tank. The computer read out would sometimes state 32 mpg but when measured on fill up it was sometimes 2 mpg off. Mercedes s class I had stated 26 mpg highway and I got 28 to 30 mpg all the time.
Wondering if RX exceeds mpg rating as well?
I'm getting 24.5, 75% highway driving.
Old Nov 1, 2024 | 08:52 AM
  #444
UrXMyXOurX's Avatar
UrXMyXOurX
5th Gear
Default Anyone noticing drastic differences in gasoline quality?
Since the pandemic, I've been getting wildly divergent mileage numbers from 2 separate vehicles: 1) 2017 Lexus Rx, 2) 2008 Chevy Cobalt.
I noticed it first in the Cobalt and thought IT might be the issue. Then I noticed the same issue in the RX.
With exactly the same driving habits in exactly the same place, I'm getting a range of 20-33% less-than-normal-mileage in both cars when the problem happens. The best mileage I usually get (see exception below) is the normal mileage I was getting prior to noticing this issue.
It makes me wonder if all the supply chain issues during the pandemic had some effect on the gas refining process or delivery process.
I've tried to stick to big-brand name gas, like Mobil. And I've also started getting higher-octane gas just to see if it had an effect (it did-10-20% better mileage, when it works).
But recently I got Mobil Supreme in the cobalt, and my overall mileage dropped to 21 mpg. My prior fillup, with Race Trac's highest grade, boosted the Cobalt's mileage to the highest I've ever seen in that car - 36 mpg.
I know 2 vehicles is a small sample size, but at this point I'm convinced that SOMETHING is going on with gas.
Any input appreciated.
Old Nov 1, 2024 | 09:11 AM
  #445
UrXMyXOurX's Avatar
UrXMyXOurX
5th Gear
Originally Posted by UrXMyXOurX
I'm going to have to do a MANUAL test-fill up, set trip meter, on next fill up calculate miles / fuel use and see what I get.
Will report back
Finally got around to doing this after noticing my fillup frequency didn't quite jibe with the numbers the RX was reporting.
And I was correct -- after manually checking MPG by comparing amount of gas used vs. miles travelled, the RX is OVERSTATING mileage by 13%.
So, that 33 mpg I reported back in Oct 22, is actually more like 28.7. Still not terrible...but disappointing to discover.
Old Nov 4, 2024 | 06:08 AM
  #446
Lexus4rx's Avatar
Lexus4rx
I still think the way computer generates is accurate.
when you do manually fill-ups, there is still residual gas left which you are not taking into account.
when I fill up my tank, sometime the miles range will say 313, or 326, or even 358. so when you fill up your tank, you actually might not be filling it all the way up. It has to do with how the gas nozzle detects gas vapor in your tank.
Old Nov 4, 2024 | 06:36 AM
  #447
UrXMyXOurX's Avatar
UrXMyXOurX
5th Gear
Hmmm...seems like simple math: miles traveled / gas used (assuming the tripmeter/odometer is accurate). The difference in fillup amount can't be THAT different each fillup .
Though if it is, it should average out over time. So, I should probably have a larger sample size than 1.
Old Nov 4, 2024 | 07:50 AM
  #448
ravenuer's Avatar
ravenuer
I've always done it manually my whole life. So I always know exactly what mileage I'm getting.
Old Nov 4, 2024 | 11:48 AM
  #449
bamalam's Avatar
bamalam
There's more to the calculated range than just the detected fuel level after fill-up. The owner's manual says this about the displayed range: "This distance is computed based on your average fuel consumption. As a result, the actual distance that can be driven may differ from that displayed." It does not say over what period the average is calculated, i.e. since reset, since refuel, since engine start. Anecdotally, it seems to be calculated over a recent period. When I've been getting better recent mileage (flat, relatively slow, few stops) the calculated range after a fill-up is always on the high side. Lower recent mileage (hilly, heavy, fast, lots of stops) yields a lower predicted range.
I did a long term (25 fill-ups) mileage test that I've previously posted. During that I noticed the indicated mileage could differ from the manually calculated mileage by +/- 1.1 mpg for a single fill-up. Over the life of the test, though, indicated and calculated mileage was within .1 mpg.
Old Dec 9, 2024 | 05:13 AM
  #450
user 79780802's Avatar
user 79780802
6th Gear
My Rx uses 20" tires set at 33psi. I always use AC and Normal mode .80% interstate driving usually 15-20 over speed limit and get 23-24 mog.City driving normal speed about same. oil change and air filter every cc 5K
