Stuck Wiper
Old Mar 19, 2026 | 12:36 PM
jfeuillet's Avatar
jfeuillet
7th Gear
Angry Stuck Wiper
Hello,
When activating the wipers from their resting position, the right side wiper appears to stick for a few short seconds then after making a loud noise, it wipes.
If the wipers are in intermittent mode, every time they start wiping again, the right side makes a loud noise and then wipes. As long as the wipers are not in their resting position, they wipe quietly like they are supposed to work.
The wiper motor and arms operate correctly and are strong and tight.
Is there a way to fix that noise?
Thanks,
Jay F.
Old Mar 19, 2026 | 12:44 PM
Does it seem like the wiper blade is sticking to the glass, or a mechanical problem?
Old Mar 19, 2026 | 12:49 PM
jfeuillet's Avatar
jfeuillet
7th Gear
It's like the blade is sticking to the glass.
Old Mar 19, 2026 | 01:15 PM
Try cleaning the blade with rubbing alcohol then wipe it down with some type of rubber treatment. Most any rubber/vinyl spray will work. Some spray waxes will also work but others actually make rubber stick to glass (personal experience).
Old Mar 19, 2026 | 01:46 PM
jfeuillet's Avatar
jfeuillet
7th Gear
Brand new wipers this PM. Still the same noise only from resting position.
Old Mar 19, 2026 | 01:52 PM
Post a video. Easy was is on Google Drive.
Old Mar 21, 2026 | 03:56 AM
jfeuillet's Avatar
jfeuillet
7th Gear
Here's the video. I noticed that the wiper was catching a rubber part on the windshield. I tucked away that part and the wiper worked fine for a few hours. Then that rubber part popped out again and was blocking the wiper blade. You can view on slow motion how the wiper blade is bent before relaxing, like a bow.
Maybe I need to glue that rubber thing on the glass away from the wiper. It's seems to be a part of the trim on the windshield glass.
I'm opened for your input. Thank you.
File Type: mov
Old Mar 21, 2026 | 04:03 AM
jfeuillet's Avatar
jfeuillet
7th Gear
The photo shows what happens
Old Mar 25, 2026 | 04:14 AM
jfeuillet's Avatar
jfeuillet
7th Gear
Default Wiper Arm Assembly
I was unable to fix the issue myself so I took the car to the dealer. The tech noted that the right wiper arm mechanism does not adjust left or right. There was no choice but to replace the complete assembly: $614 dollars later the wipers now work well, no noise, smooth action.
In the photo, the wiper arm assembly replaced.
Old Mar 25, 2026 | 05:39 AM
autotech13's Avatar
autotech13
Looks to me that the wiper blade is too long. Did you check to see if they were switched?
Old Mar 25, 2026 | 07:25 AM
jfeuillet's Avatar
jfeuillet
7th Gear
Wipers were the correct length and type. I'm not sure what happened. I just bought this car last month and I know it used to be in the Chicago area. Maybe snow and ice were built up and the wiper arm was bent by the weight.
bmx
RX - 3rd Gen (2010-2015)
17
Jun 2, 2023 01:53 AM
NSG
Apr 27, 2019 11:35 AM
semar
Jan 14, 2016 02:33 PM
sonyman
Jul 1, 2007 08:22 PM
