Multiple warning messages
Old Mar 21, 2026 | 12:11 PM
beefnoodle's Avatar
beefnoodle
Default Multiple warning messages
Hi all !
Yesterday I had a "check fuel cap" message that popped up and went away. Which I did check, everything seemed ok. This morning a "Secondary Collision Break system Malfunction" and a "AWD System Malfunction 2WD Mode Engaged" message popped up along with the yellow check engine light.
Has any one else experienced this, and how was the situation remedied?
Car has about 60k km on it and it has been some what cold here -3 on some days. I live 1600km away from the nearest Lexus dealership. Thanks everyone.
Old Mar 22, 2026 | 01:09 AM
Nevada's Avatar
Nevada
When the check engine light is on, the support systems (collision mitigation and auto AWD) will be temporarily unavailable.
The "Check Gas Cap" message was an early warning indication of an evaporative emissions system leak. Recheck the fuel cap seal. After the problem is corrected, the check engine light should no longer be on after two days of driving.
Old Mar 22, 2026 | 08:58 AM
Clutchless's Avatar
Clutchless
Also check your 12 volt battery as when they begin to fail and have lower voltage it will trigger many apparently random warning lights and codes because everything is very sensitive to low voltage. Batteries are very sensitive to cold weather and that is often what it takes to make them fail. Your recent cold weather is a great indicator tthat it is likely your old battery. Note that even if somewhat new that any battery can fail at any time.
Old Mar 22, 2026 | 10:00 AM
ravenuer's Avatar
ravenuer
Originally Posted by beefnoodle
Hi all !
What year is your Lexus?
Old Mar 24, 2026 | 06:23 AM
evident's Avatar
evident
These days in the north east where it's 70 degrees one day and 20 the next really takes a toll on old batteries.
Old Mar 25, 2026 | 10:07 AM
beefnoodle's Avatar
beefnoodle
Apologies, don't know how to delete this.
Old Mar 25, 2026 | 10:08 AM
beefnoodle's Avatar
beefnoodle
It's a 2022!
kjkcjk
RX - 3rd Gen (2010-2015)
19
Feb 4, 2025 06:15 AM
ACP84
NX - 1st Gen (2015-2021)
Feb 11, 2022 12:46 PM
Jsoto517
IS - 1st Gen (2001-2005)
May 10, 2018 08:04 AM
