Steering Not Correcting
Old Apr 16, 2023 | 06:35 AM
realast8's Avatar
realast8
4th Gear
Default Steering Not Correcting
I have a 2017 RX350. This morning I noticed that my steering was not correcting all the way after making a turn at an intersection. If I left it alone, I would have hit the curb.
Any idea why this is happening?
Old Apr 16, 2023 | 08:33 AM
ravenuer's Avatar
ravenuer
Simple things first....check the condition of the battery. How old is the battery? If it's original, it may be time for replacement.
Old Apr 16, 2023 | 09:26 AM
realast8's Avatar
realast8
4th Gear
Battery was replaced 2yrs ago.
Old Apr 16, 2023 | 09:37 AM
TechNut's Avatar
TechNut
Veteran: Navy
This seems like a suspension problem, not an electrical issue. Can you explain why you think the battery could be the cause?
Personally, I would be checking the inflation/wear of the tires, alignment and other suspension hardware. Sounds like time to visit an alignment shop or the dealer?
Old Apr 16, 2023 | 10:49 AM
ravenuer's Avatar
ravenuer
Because it has electric power steering and battery issues have often caused steering problems. That's why I said simple things first. If that checks out, he should certainly look at what you suggested.
Old Apr 16, 2023 | 11:02 AM
realast8's Avatar
realast8
4th Gear
Tire and Tire pressure is good. I'll look into the alignment and suspension.
Old Apr 16, 2023 | 04:46 PM
FastFord's Avatar
FastFord
Steering issue, tie rods etc...or easy check...how's the power steering fluid?
Old Apr 16, 2023 | 05:09 PM
ravenuer's Avatar
ravenuer
Electric PS. No fluid.
Old Apr 17, 2023 | 10:22 AM
FastFord's Avatar
FastFord
I knew that...must had a few too many yesterday!
Cheers
Old Apr 17, 2023 | 12:15 PM
mrmonster's Avatar
mrmonster
I just started experiencing this on my '17 it was less noticeable on soft winter tires but now back on the Michelins and there's something wrong with the steering. It's very tight to turn while in motion, does not feel smooth and will not return to center by itself.
At first I thought maybe I hit a pothole and screwed up the alignment but this feels like something else. I looked at suspension components while I was swapping winter tires last week but everything seemed normal from a quick visual inspection.
Battery is good, replaced it last fall.
Old Apr 17, 2023 | 12:57 PM
ravenuer's Avatar
ravenuer
Cheers
Too much fluid, heh? !!
davidtth
Nov 2, 2022 09:02 AM
mandato
RX - 4th Gen (2016-2022)
Jul 3, 2021 04:24 AM
WILLIAMBLR
Jul 1, 2018 03:08 AM
ewcarter
Jan 10, 2009 02:25 PM
