Hello - I installed a hitch on my 2013 RX 450H from etrailer.com and used
Curt T-Connector Vehicle Wiring Harness for Factory Tow Package - 4-Pole Flat Trailer Connector
Item # 56083
Before ordering I removed the lower panel and was able to locate the connector on driver side so I assumed this RX has the pre -tow package already. I pulled off the cap and simply plugged in the adapter but the light are not working. Would this need to be enabled at the stealer?
It goes passenger side of the rear hatch, when you remove the trim you'll see the plug hanging there and a hole to mount the part.
These are about $100 on the internet and more at the dealership, way more if the dealer installs it.
Not a difficult job. Search for threads with this part number.
