Flat key question
Old Aug 10, 2012 | 03:01 PM
MachineMan's Avatar
MachineMan
Default Flat key question
Does the flat wallet key come standard with the 2013 RX350? I see it in the 2013 manual but all I received were two remote starter remotes. Can this be purchased?
Old Aug 10, 2012 | 03:10 PM
dctex99's Avatar
dctex99
key releases from remote! Didn't your salesman show you this????
Old Aug 10, 2012 | 03:32 PM
MachineMan's Avatar
MachineMan
Default Yes, but manual states you need the flat key to start
the car should the main remote battery become depleted.
Old Aug 10, 2012 | 03:37 PM
mrsunny's Avatar
mrsunny
There is a small button on the side and upon pressing that the white bottom portion on the key fob which has a tiny ring comes out with a key. This key can be used to lock your glove box to store any valuables when giving out the car to valet parking etc
Old Aug 10, 2012 | 03:44 PM
mrsunny's Avatar
mrsunny
My car salesman said that even though the key fob battery dies you can still use it to start the car by placing the remote key next to the start button and pressing it and it should start the car and you don't actually have to use the key. I saw a youtube video on that but can't seem to locate it right now...
Old Aug 10, 2012 | 03:49 PM
mrsunny's Avatar
mrsunny
Sorry don't mean to flood the thread but was finally able to find the video. Here you go...
Old Aug 10, 2012 | 04:48 PM
UCSB's Avatar
UCSB
^^ I don't think the question is about the manual key ... but, rather does the credit card sized electronic wallet key come standard. The answer is no, it is not standard. Here is the version for 2013:
http://lexus.sewellparts.com/accesso...2013/4630.html
It might be standard with the luxury package, I don't know all of the package config's for 2013.
Old Aug 10, 2012 | 05:25 PM
BertL's Avatar
BertL
As UCSB says, the true "flat key" that is the size of a credit card and was standard on previous models of RX such as my 2006 RX400h, is no longer standardly provided with a new 2013 for example. You used to get three keys, two what you'd consider normal keys with all their remote buttons that could both open the doors and start the car, and a single key with no remote buttons, but was a flat (and fat) credit-card sized piece of plastic with a "flat key" within it that could be removed and inserted into the car door AND ignition to unlock and start your truck. My 2013 (with luxury pkg) only came with two electronic "keys" that have the ability to remove a physical key that only unlocks the door -- you still need the electronic part to actually start the truck. If you need something like the old credit card version that has both the physical key for the door and the infamous chip in the rest of the credit card plastic carrier that your ignition needs to start, I suggest you check with Lexus Parts -- that is your only alternative -- it's no longer standard with the new car purchase.
Last edited by BertL; Aug 10, 2012 at 07:28 PM. Reason: Edited to add clarity (I hope)
glennheff
Jul 9, 2017 05:41 PM
hoonunya
May 23, 2012 05:41 PM
cubabarber
May 18, 2012 10:22 AM
kennyboy
Jan 31, 2011 06:10 AM
lexusis250
Jan 3, 2006 02:43 AM
