"Check AWD System" Warning Message (merged threads)
Old Sep 11, 2022 | 03:54 AM
  #166
RX in NC's Avatar
RX in NC
Read the OBDII codes and report them here.
Old Sep 11, 2022 | 09:11 AM
  #167
Clutchless's Avatar
Clutchless
Check your battery. If it is weak the low voltage can trigger various warning lights. Most chain car parts stores can check your battery then sell and install a new one.
Old Sep 11, 2022 | 03:30 PM
  #168
devonks's Avatar
devonks
Clutchless, Thank you. I will have my battery checked but one thing that is suprising is that the error goes away after I full the tank, everytime I encounter the check AWD error, I fillup the tank with gas and that resets the trip computer and goes away. It again came back second time and I did the same and it was gone. Now my tank is full, I havent got the error yet but most likely it ll come back after certain fuel level.
Old Sep 12, 2022 | 07:39 AM
  #169
Clutchless's Avatar
Clutchless
Your check lights are possibly due to a bad sender unit in the gas tank. As stated above you need to scan for stored codes. It may be time to have a shop look at your RX, not a dealer, but an independent repair shop that works on Toyotas etc.
Old Sep 12, 2022 | 03:07 PM
  #170
devonks's Avatar
devonks
Exclamation OBDII scanner and battery test results
Thank you Clutchless, These are the codes in the picture for the OBD2 scanner and another attachment for battery test. When I scanned it for the check engine light, the check engine light was OFF.
Battery Test
OBD2 scanner
Old Sep 12, 2022 | 04:24 PM
  #171
Clutchless's Avatar
Clutchless
I hope your issues go away after replacing the battery! That low voltage makes you think a hundred different unrelated things are wrong at the same time.
Old Sep 12, 2022 | 04:39 PM
  #172
devonks's Avatar
devonks
Thank you Clutchless,I think at this point I will start with the battery replacement as a first step and go from there. Will keep posted! in the meantime, want to thank everyone for the inputs.
Old Sep 12, 2022 | 05:00 PM
  #173
devonks's Avatar
devonks
One more question Clutchless, the attendant measured the battery when the engine was OFF and the reading above was based on the engine being OFF, Would that test reading be still Okay with engine OFF battery test?
Old Sep 12, 2022 | 05:52 PM
  #174
Clutchless's Avatar
Clutchless
I don't know that answer. I assume the attendant knew what he was doing so that we may assume the test results are valid.
Batteries do fail all the time and often much sooner than expected. Modern vehicles with all the electronics are very hard on batteries.
That is why I splurged for an AGM battery when my 2016 Sienna needed a battery and it is the same as the RX mechanically but being newer has more electronic stuff on it.
Old Sep 13, 2022 | 04:24 AM
  #175
RX in NC's Avatar
RX in NC
12.71 volts with the engine off is typically okay but may be borderline in these vehicles (which are essentially rolling computers). What did the battery voltage measure with the engine running?
I replaced the 4.5 year-old battery in my wife's 2006 Jaguar XK8 last month. It measured just 11.75 volts with the engine off so it was definitely on its way out. I replaced it with the appropriate AGM battery (built by East Penn) from my local NAPA store. My experience the last five years or so is that East Penn builds longer-lasting batteries than Johnson Controls does. They are the two main vehicle battery companies in the U.S.
Old Sep 13, 2022 | 09:11 AM
  #176
devonks's Avatar
devonks
While testing the batteries yesterday, the attendant did not mention to turn on the vehicle at all, Should I again perform a test with the car in ON position? TIA
Old Sep 17, 2022 | 04:41 PM
  #177
devonks's Avatar
devonks
Exclamation
Just changed to new battery yesterday sept 16 and today sept 17 while driving again had check AWD warning and again when the fuel was in 3/4th. This time I long pressed traction control and power button and then the check AWD warning with check engine light went off. Not sure why and how. I checked my gas cap rubber ring and it seems alright, cleaned the gas cap well.
Now seems like even with the new battery this issue is showing up my focus now is on tire or gas cap. I always fully close the gas cap and gas cap ring also seems OKAY.
I remember when the mechanic few days back scanned check engine code c1403 and 1407 with the rear sensor can possibly trigger check AWD warning?
Thanks in advance.
Old Sep 18, 2022 | 08:35 AM
  #178
Clutchless's Avatar
Clutchless
Try disconnecting the new battery for 30 minutes to clear everything ( you may lose some presets for seats and radio etc) and maybe that will erase the codes.
Old Sep 20, 2022 | 07:38 AM
  #179
RVH's Avatar
RVH
I haven't read this entire post, but this has happened three times in the 12-yrs with my 2010 RX 350 (177k miles). Each time I scanned for the code, cleared it and it didn't come back for years. I'd do that first and if the check-engine/AWD warnings happen again, bring it in.
Old Sep 20, 2022 | 08:36 AM
  #180
RX in NC's Avatar
RX in NC
^^ You could not have owned a 2020 RX350 for 12 years. Something is amiss here.
