Air Con stinks like sweat
Old Jan 26, 2010 | 01:51 PM
euroja153's Avatar
euroja153
Default Air Con stinks like sweat
Lately, we have noticed a sweat like smell in the car, we dont keep any dirty clothes or shoes in the car, I am pretty sure its coming out of the air con vents. Has anyone else got this or does anyone know what may cause this? Thanks
Old Jan 26, 2010 | 03:59 PM
Stormforge's Avatar
Stormforge
executive matchup
it's mold inside the vents, quite common among cars with A/C. you need to crank up the heat and let it run for awhile to get rid of any moisture inside the vents.
Old Jan 26, 2010 | 05:47 PM
RXSF's Avatar
RXSF
in general, there are only two ways you can prevent this from happening:
1) leave the air con on all the time
2) use the aircon (cold) when necessary and then about 8 minutes before you destination, switch off the AC compressor but leave the fan going.
Old Jan 26, 2010 | 10:28 PM
sophos's Avatar
sophos
You could also try one of the duct cleaning products:
http://www.autogeek.net/clean-air-fogger.html
http://www.autogeek.net/megcarodel.html
http://www.scoe10x.com/
I'm sure there are others...
Old Jan 27, 2010 | 03:09 AM
euroja153's Avatar
euroja153
Thanks everyone, I guess it must be because I have the A/C on the front window all the time as its winter, mould must be building up in the pipes of the face facing vents.
Old Jan 27, 2010 | 01:27 PM
Stormforge's Avatar
Stormforge
executive matchup
correct me if i'm wrong on this...these products do work, but they only mask the problem rather than treating the problem. i recall reading somewhere that the smell does come back after treatment?
Old Jan 27, 2010 | 02:25 PM
euroja153's Avatar
euroja153
Tried doing this, ran the AC on full fan and HI temp but it doesnt seem to have worked. I wonder if there is any point in asking Lexus to look into it?
Old Jan 27, 2010 | 03:24 PM
Stormforge's Avatar
Stormforge
executive matchup
next step would be to try the sprays sophos recommended and see what happens. if it comes back, take your car back to the dealer for a more thorough examination
Old Jan 27, 2010 | 03:53 PM
RXSF's Avatar
RXSF
what the dealer will do is spray some of that odor maskers into the vents. They wont actually remove the mold
Old Jan 27, 2010 | 08:06 PM
tazdevl's Avatar
tazdevl
They generally spray with a disinfectant (lysol) which does kill mold then follows up with a deoderant spray which masks the smell of lysol or they just use a specialized product that does both.
The spray goes in the cabin intakes in the footwell and the AC is put on recirculate... problem is it needs to circulate through and treat the entire system which is why it typically takes more than one shot.
They could spray more, but folks would be driving around in hazmat suits.
Old Jan 28, 2010 | 07:23 PM
Cruiter's Avatar
Cruiter
It can happen on any car if the A/C hasn't operated for an extended period and then is cut on. If you use it in the default setting and 'AUTO' then the A/C will cycle on and off as needed and help control the defroster as well. A side benefit will be better humidity control in the cabin. It's the way it's designed to operate.
Old Feb 10, 2010 | 08:31 PM
willie007's Avatar
willie007
That smell is mold! Mold is only common in an automobile air-conditioner when the air-conditioner is designed incorrectly. Mold is bad for your health. Take your car back to the dealer and demand that they replace all parts need in order for the condensation to drain properly. Do not let them spray anything in it the system must be replaced. They know what parts are needed.
600rr
Jun 15, 2017 02:49 PM
vartig
RX - 3rd Gen (2010-2015)
May 2, 2015 11:29 PM
glm
Dec 9, 2014 09:00 AM
wise2k
Jun 27, 2013 07:17 AM
PhilipMSPT
Automotive Care & Detailing
Jan 9, 2007 11:16 PM
