Need HELP! SRS Warning After Fuse Blown
Old Oct 1, 2025 | 06:51 PM
socaligs's Avatar
socaligs
Default Need HELP! SRS Warning After Fuse Blown
Installing ambient LED and it seems that one of the fuse is blown and SRS warning is on. All the windows do roll down with remote and close with key blade. However, the driver side window switch and all the window switches do not roll the window down. It seems that everything works but the window switches does not work. Tried to replace couple fuse and the problem still exist. Can anyone help. Thanks in advance.
Old Oct 2, 2025 | 01:40 PM
Clutchless's Avatar
Clutchless
Replace LED bulbs with original bulbs. Replace fuses. See if the windows work. See if it happens again. If it does not blow a fuse and the windows work, then the cause was your new LED bulbs. if they don't work you may have damaged a relay or something else.
They may lack Canbus, or may draw too much current etc. Or may be defective cheap junk bulbs.
That's all I have to contribute for diagnosis.
BeeVee
Dec 12, 2024 06:51 PM
ERW
NX - 1st Gen (2015-2021)
Apr 11, 2023 05:39 AM
slickster
Jun 12, 2021 03:01 PM
valenzuela
Feb 9, 2020 06:03 PM
Jay.Diem
Apr 30, 2010 03:51 PM
