Check Headlight System ( 2012 RX-450h )
Old Feb 20, 2025 | 09:00 AM
Riickk's Avatar
Riickk
Unhappy Check Headlight System ( 2012 RX-450h )
I'm getting a Check Headlight System message on my 2012 450h. Car is new to me, I think the headlights are the triple LED version; output doesn't look like HID bulbs to me.
Headlights look new, driver's side has moisture/water inside, which is (my guess) the culprit.
Research so far says water inside headlight = corrosion of wiring connections, or, could be a a loose whatsis, or, maybe the suspension part that signals the computer about ride-height is mis-adjusted (previous owner had new lower control arms + ball joints installed - 6,000 miles ago), or, there's a bad auto-leveling motor. Have not disconnected battery to see if that will help, do know that shutting down the car makes message go away until headlights are switched on again.
Worst case, I already know I can pull the fuse powering that system, and then ignore the problem - no message will show up again, but would rather have things working properly.
Anyone with experience with this issue ?? or can point me to a DIY for removing the headlight assembly?
Old Feb 20, 2025 | 09:32 AM
Clutchless's Avatar
Clutchless
You have HID headlights bulbs, not LED.
The suspension headlight height sensor is on the rear suspension, not the front.
Your issues are all probably related to water in the light housing.
However some condensation inside the housing is normal as long as it evaporates during the day.
There are YouTube videos on how to remove it and it is covered in some of the links below. The HID headlamp assemblies are very expensive to replace and I would first try to seal it yourself with some heat resistant RTV silicone sealant or whatever is recommended in the linked threads.
See these related threads:
https://www.clublexus.com/forums/rx-...-moisture.html
https://www.clublexus.com/forums/rx-...e-fogging.html
https://www.clublexus.com/forums/rx-...placement.html
​​​​​​https://www.clublexus.com/forums/rx-...ng-system.html
​​​​​​https://www.clublexus.com/forums/rx-...ment-help.html
These discuss removal of the headlamp assembly.
https://www.clublexus.com/forums/rx-...eadlights.html
​​​​​​https://www.clublexus.com/forums/rx-...placement.html
Old Feb 20, 2025 | 12:57 PM
Riickk's Avatar
Riickk
Thanks for the information!!
Yes, I've watched several YouTube videos on pulling the headlight assembly, as well as one on DIY opening and then resealing the headlight assembly so it's water tight. I don't want to have to do this job twice.
What's amazing, is that you can now buy new polycarbonate (?) covers for these headlights, cheap. UV damaged headlights can be disassembled, cleaned, and a new clear cover fitted. When done it looks brand new. I'm going to guess that you'll get well over 5 years out of that. Pulling the bumper will be a PITA, but worth the effort.
Old Feb 20, 2025 | 05:56 PM
salimshah's Avatar
salimshah
25 Year Member
Other than auto-leveling there is an option offered by Lexus where the headlights turn side ways, in the direction of turn (steering wheel turn direction).
Salim
Old Feb 22, 2025 | 03:28 PM
Riickk's Avatar
Riickk
I removed the plastic engine covers, and found the driver side headlight was clearly damaged at some point. Two (or more) mounting point tabs are ugly-expoxied back together. There is a small 12v motor as part of the assembly, guessing it does the auto-leveling. My very bad, should have had mechanic pull the engine covers for a good look, before buying the vehicle. Too late is much too late.
Researching, I found a company who's selling new aftermarket HID/Xenon headlamps for the 2010-11-12 RX, at an excellent price. However, their units have "AFS" - which does left/right adjusting iirc. Any way I can tell if my headlights I have also have AFS??
Old Feb 23, 2025 | 05:27 AM
Clutchless's Avatar
Clutchless
If you have a 2012 with HID then you have AFS. They stopped providing AFS with the 2013 mild refresh.
To test it drive at night and when going around corners or turning the steering wheel note if the headlight beams appear to move left and right as you turn the steering wheel and car.
You could probably do this test while parked and just turning the steering wheel.
Old Feb 24, 2025 | 09:45 AM
Riickk's Avatar
Riickk
Well the dream was sweet while it lasted. The company selling the new headlights got back to me and the electrical connectors are for the 350 and not for the 450h, won't work. Hooked a hair dryer using low heat, to the headlight assembly, for 40 minutes, trying to dry it out. Still getting the check headlight system message.
I have Techstream; I'm wondering if the DTC for this message (B2430) needs to be cleared for the message to go away, or will disappear after x number of miles??
Old Feb 24, 2025 | 10:06 AM
RX in NC's Avatar
RX in NC
My guess is that you will need to clear that OBDII code.
Old Feb 24, 2025 | 11:15 AM
Riickk's Avatar
Riickk
I'm using version 16, and though logically there would be a button, pop-up, etc. to erase a DTC... Don't see it.
~~~ Just reviewed a manual for version 18, erasure ability is there. Need to look at live screen again.
Old Feb 24, 2025 | 05:24 PM
Riickk's Avatar
Riickk
Erased the B2430 code, twice, but a minute or so after headlights are turned on, the code returns.
I know the leveling system is working, and so is the afs system.
What's left? Corrosion at the electrical connectors so that the computer sees too much resistance at one terminal or another?
Old Feb 25, 2025 | 04:45 AM
Clutchless's Avatar
Clutchless
Corrosion is the most likely source for the code.
Did you check and clean all the wiring connections to the bulbs and the ballasts? Make sure there is no corrosion.
If you have the original bulbs, try replacing them as maybe one is going bad, and they do get dimmer over time, so you will improve night vision with new bulbs. It is a D4S HID bulb and good brands are Osram, Philips, Toshiba, Hella which are available online at places such as Amazon. Do not touch the new bulbs with bare skin as the oils create hot spots that make the bulb burn out sooner.
Old Feb 25, 2025 | 07:56 AM
salimshah's Avatar
salimshah
25 Year Member
When you get any error being reported, it means the system is not operating in normal/expected range. We as humans can observe a change happening and your conclusion can be based on that movement. There is another aspect where the change/movement is all correct but the computer gets bad/incorrect info from a sensor. In a nutshell, things are not perfect. Other than infamous corrosion, look for loose connections. If some one has worked on this problem, they might have used thick probes which may have deformed the connector. More info on "drag test".
Salim
Old Feb 27, 2025 | 05:24 PM
Riickk's Avatar
Riickk
I'd rather work on it myself, but I'm stumped at this point. The error code "meaning" is too broad. Of course the Techstream version I have won't communicate back to Toyota servers. ?? But, does this matter ?? If I take the vehicle into Toyota or Lexus Dealer, for diagnosis, will they get a more precise picture of what the problem is, or just the same error code I already have. In the same vein, if I go to the TIS website can I download the repair manual, or just use the Manual during the subscription period? (( The last time I tried using that site was so long ago, I may have been using most modern tech available to consumers at that time.... a 4800 or 14.4K modem.))
Old Feb 28, 2025 | 08:42 AM
Clutchless's Avatar
Clutchless
Try to find an independent Toyota specialist, or Japanese car specialist rather than a dealer.
Old Feb 28, 2025 | 11:30 AM
salimshah's Avatar
salimshah
25 Year Member
I totally understand and am with you, BUT, a good DIY person knows when to ask for professional help. Better still who to ask? No guarantees but if the diagnosis is based on time, then I would willingly pay more $/hr to a savvy tech then try to find cheaper rate which would end up in lot more time. [This includes tools and network available to the tech].
Incidentally I am hearing that techstream may soon be replaced with a more modern version.
Salim
