Rain Sensor Metal Bracket Adhesive
Old Dec 9, 2025 | 07:42 AM
RXPenn's Avatar
RXPenn
Originally Posted by 6runner
Noticed that you've mentioned scraping and alcohol cleaning surfaces but not sanding. Permatex rear view glue kits I've used come with sand paper to rough up glass and metal surfaces which increases surface area and adhesion. As a suggestion I'd also apply some pressure for several hours to the metal tab while glue is setting using a stick of wood cut to length or a screw type shower curtain propped up from the back seat perhaps. Best of luck with this repair.
We've had good success with 3M High Bond Rear View Mirror Adhesive ;
https://www.3m.com/3M/en_US/p/d/b40066497/
Thanks for the input and suggestions. I don't think any of the review mirror kits I've ever used suggested sanding, but probably not a bad idea though
Each time I've done this I've applied pressure, used tape across the bracket to keep pressure on for 24 hours. However, I never thought of trying that using a dowel etc. Also a good suggestion. I'll definitely try that next time.
Currently it's been in the 20's here the past week so I haven't tried reattaching it yet.
Sal2030
Jun 26, 2024 08:22 AM
mmsafd
May 17, 2024 10:44 PM
m1964
RX - 3rd Gen (2010-2015)
May 7, 2022 06:34 PM
Band
Jan 30, 2017 01:32 PM
LS/SC
May 14, 2006 03:21 PM
