Headlight turns off after a little bit
Old Dec 30, 2023 | 12:57 PM
glints's Avatar
glints
6th Gear
Default Headlight turns off after a little bit
I've got a Lexus RX 350 2012 and not sure what to do because the passenger headlight turns off after the car runs for a couple of minutes. On the passenger side the regular light works for a short bit, the high beams work all the time and the turn signal also works, but the rest of the lights don't work (not sure what they are exactly called). On the driver side, all the lights work as expected. Thoughts on what I should check?
Video of lights working right after I turned the car on: https://streamable.com/yj3b6y
Old Dec 30, 2023 | 02:06 PM
Clutchless's Avatar
Clutchless
See this then tell us if you have halogen or HID headlights. It makes a difference in attempting a diagnosis.
https://www.clublexus.com/forums/rx-...eadlights.html
Old Dec 30, 2023 | 02:43 PM
glints's Avatar
glints
6th Gear
The links to the vehicles in that thread don't work, but here is a video of my car: https://streamable.com/yj3b6y
Old Dec 30, 2023 | 05:02 PM
RadiantX45's Avatar
RadiantX45
You have HIDs. It’s going bad. Time to replace.
Old Dec 30, 2023 | 05:08 PM
glints's Avatar
glints
6th Gear
Ok. So that's normal behavior? I don't have to worry about anything worse?
Old Dec 30, 2023 | 05:17 PM
HID bulb lasts about 2,000 hours. Could also be the ballast but given the age of your car replace the bulb first.
Old Dec 30, 2023 | 05:19 PM
glints's Avatar
glints
6th Gear
Thank you. Any recommendations on bulbs?
Old Dec 30, 2023 | 05:44 PM
These are highly regarded
Amazon Amazon
It might not match exactly the colour temperature of your other bulb (or brightness), a new Lexus original might not either not a bad idea to replace them in pairs.
Old Dec 31, 2023 | 11:56 AM
Clutchless's Avatar
Clutchless
I agree, you should replace both bulbs as they do get dimmer over time and miles. Your other bulb is certainly going to be dimmer than a new bulb and may also soon fail.
Old Jan 2, 2024 | 03:52 PM
glints's Avatar
glints
6th Gear
https://www.amazon.com/dp/B00480J4I2
Thank you! I ordered these a couple days and installed them tonight and they worked great! I think my problem is solved as they didn't turn off at all.
glints's Avatar
glints
6th Gear
I did exactly that and it seems to be working great! Thank you so much for your help.
Old Jan 3, 2024 | 04:19 AM
RX in NC's Avatar
RX in NC
Well done.
Robbie2j
GS - 1st Gen (1993-1997)
Apr 1, 2018 05:09 PM
Yurka
RX - 3rd Gen (2010-2015)
Sep 26, 2016 09:03 AM
LexiLex
Jan 25, 2013 12:20 PM
Shawnalk
Apr 21, 2010 10:46 AM
TAP4636
May 13, 2009 09:25 AM
