window & cd malfunction
Old Jul 22, 2017 | 12:05 PM
ABOWDEN's Avatar
ABOWDEN
Default window & cd malfunction
I just had my radiator replaced on my RX330 -2004 & when I got it back I noticed the time was off 2 days later I went to open the passenger side window & it would not go down (it goes down when controlled by passenger. the window lock is off
also the 6 disc player will only play 3 & I know there are others in player
WHAT COULD HAVE HAPPENED??
Old Jul 22, 2017 | 02:21 PM
Lexuswiz's Avatar
Lexuswiz
Seems like they pulled the battery which is reasonable for a radiator job. For the windows, you'll need to do a reset which relearns the window movement a search on this sub-forum will yield results. No idea on the radio, have you tried ejecting all 6 then inserting them again?
Old Jul 22, 2017 | 04:51 PM
05RX330AWD's Avatar
05RX330AWD
For the windows you need to lower each window half way, then back up to close & hold the button towards the up position for at least 1 second.
This procedure must the done for each window individually from the same door the window is located.
Otherwise you can not do this with the driver's door window switch for the other 3 windows.
The CD issue is odd, whenever I had to disconnect the battery with 6 CDs loaded, the CD Player would start at CD 1, Track 1.
Try to eject all, Mode should take you to the Radio, then insert 1 CD & check if it Plays as CD 1, Track 1, then load the rest.
Old Jul 22, 2017 | 05:13 PM
ABOWDEN's Avatar
ABOWDEN
so you think this will allow m e to control the other windows from the drivers seat?
Old Jul 22, 2017 | 05:21 PM
ABOWDEN's Avatar
ABOWDEN
Than you for your response.. so you feel that this reset will give me control of all windows from the drivers seat?
Old Jul 22, 2017 | 05:28 PM
05RX330AWD's Avatar
05RX330AWD
Absolutely, it's actually the only way, went through this procedure several times as I had to disconnect the battery for DIY repairs.
Now I know this procedure by heart, if you have a sunroof, you need to hold the close Sunroof switch until it opens & closes completely on it's own.
Old Jul 22, 2017 | 05:37 PM
ABOWDEN's Avatar
ABOWDEN
got the windows reset THANK YOU very much, this was bothering me all day. did what you said with the cd player, no correction--- but thinking about it all the cd that were ejected were store bought--- the 3 that didn't come out were home made, any thoughts????
Old Jul 22, 2017 | 05:40 PM
ABOWDEN's Avatar
ABOWDEN
yes got 3 store bought cd's out but the 3 home made didn't come out , any thoughts??
Old Jul 22, 2017 | 05:51 PM
ABOWDEN's Avatar
ABOWDEN
got the windows to work, thank you very much. the cd player ejected 3 store bought cd's but not the 3 home made, any thoughts
Old Jul 22, 2017 | 06:54 PM
Lexuswiz's Avatar
Lexuswiz
Does it show the CD's are in the slots? I have a little disc symbol for each disc inserted. If not, are you sure they are in there? If so, then I feel like the radio is on its way out.
Old Jul 23, 2017 | 03:19 AM
05RX330AWD's Avatar
05RX330AWD
As a rule, Lexus stereos are not particularly fond of self burned CDs although I burn mine in .wav format & they play fine.
The issue could be the inferior quality of the CD itself.
Do you receive any error messages?, list of messages from the RX Manual in the photo:
Old Jul 23, 2017 | 10:37 AM
JoeInHNL's Avatar
JoeInHNL
Post number 3 in this thread might help with your CD problem:
https://www.clublexus.com/forums/rx-...error-4-a.html
Old Jul 23, 2017 | 11:08 AM
ABOWDEN's Avatar
ABOWDEN
no error message the screen just shows 3 cd's although it is a 6 cd player
JLH8432
RX - 1st Gen (1999-2003)
Jul 7, 2017 06:33 PM
Weidnera
May 25, 2017 01:54 AM
Leines
May 8, 2012 01:22 AM
elvis1955
Feb 19, 2012 10:42 PM
