Feb 21, 2012 | 10:20 AM
Rx 330/2005
The typical issue I have is moisture in the headlight and HID stopped working. My is HID and AFS (dealer price is 2K !!)
Question: can I use HID only headlight assembly to replace current with AFS (of course I would change both sides). Would this create any problems? Same connectors? What about AFS indicator on dashboard?
I intend to change bulb only and see if this works, but if not, I may need to do more to fix this.
Many thanks for any ideas!
Reply 0
Feb 21, 2012 | 11:04 AM
Was the HID bulbs not working or both HID and AFS?
If AFS is working, I would just replace the bulbs and seal the headlights...here's the DIY link
https://www.clublexus.com/forums/rx-...densation.html
Reply 0
Feb 21, 2012 | 01:34 PM
Didn't think of this one .... many thanks! I think AFS works as there is no indication on dashboard. Also bought bulbs from eBay ($20, Chinese stuff but I hope it works ). This is my first choice approach ..., but if unsucesfull can I change the whole headlight assembly just with HIDs? Dealer does not want to provide straight answer, so I find this a bit suspicious.
Reply 0
Feb 21, 2012 | 01:49 PM
most likely the AFS works fine...you might need to replce the bulb (not sure about the ballast)....
good luck and keep us posted
Reply 0
Feb 25, 2012 | 07:35 AM
You were right, AFS works ... good news. Just waiting for the bulb to arrive and will try if works. I hope ballast is OK too as I removed moisture some time ago (hair blower - works great) and since there is no moisture, my hopes up. Will keep you posted - thanks a lot for help!
Reply 0
Subscribe
