Second Time RX Owner
Old Sep 27, 2009 | 05:57 PM
electric13's Avatar
electric13
Default Second Time RX Owner
just and intro here since i've been a lurker, but haven't posted much. We used to have a 2000 RX300. we had it till 200k miles. we then made the mistake of trading it in for a 2006 Ford Escape. after 85k miles, the transmission started slipping. so we went back to the lexus dealer and they gave us an offer on a 2007 CPO, and a trade in value on the POS Ford that we couldn't pass up. so now, i'm back in an RX. 2007 RX350 and lovin life again. the only thing i don't like is the halogen lights. i've just read through 10 pages of threads and am still wondering if it's possible to pull these out and put in some HID projector housings with the stock wiring. i also have a 2002 Honda Civic that I retro'd in some Acura TSX HID projectors. the ballasts pull about 15A on inrush, so i had to build a relay harness. the stock wires couldn't take it. so if i have the halogens on the 2007 RX350, can the stock wires handle the xenon projectors? or am i going to have to do a relay harness on this too? does the SUV have the same power wiring regardless of which headlight is in there?
Old Sep 28, 2009 | 12:47 PM
mowmow's Avatar
mowmow
Hi there, you can always do a retrofit but require to do a relay harness. What kind of projectors are you thinking to retrofit into the RX ?
Old Sep 28, 2009 | 01:27 PM
electric13's Avatar
electric13
i want to buy the OEM RX projectors, housings, ballast, all of it and just swap out my halogen housings. i don't want to do a retro. i figure it won't be too hard since xenons were an option. i would think the stock wiring would be setup to handle either halogen or xenon.
Old Sep 28, 2009 | 02:09 PM
voodoojc's Avatar
voodoojc
Probably cheaper/easier to buy a whole headlight housing with HID.
Old Sep 28, 2009 | 07:58 PM
electric13's Avatar
electric13
that's what i was trying to say in my previous post. i'm just wondering if the stock wiring can take it. is it the same power harness OEM whether you have halogen or HID? if the wire gauge is the same, then i'll just buy the xenon housings with ballast, bulbs, etc off ebay and swap them out. the variable i don't know about is the AFS. i know the actuator is in the housings, but the servos would have to get a signal from the car. is that signal in all cars and just not used?
Old Sep 29, 2009 | 04:38 AM
tromly's Avatar
tromly
+1 voodoojc, a whole lot cheaper
Old Sep 29, 2009 | 11:24 AM
electric13's Avatar
electric13
yep, that's what i want to do, but what about the wires?
Old Oct 3, 2009 | 09:17 AM
mowmow's Avatar
mowmow
Well you get what you pay for....the premade stuff are pretty much worst than factory OE
Old Oct 11, 2009 | 12:23 PM
electric13's Avatar
electric13
as i stated before, i'm going to buy OEM housings with the projectors, ballasts, etc. what about the wires?
Old Oct 12, 2009 | 04:46 PM
mowmow's Avatar
mowmow
you will need to have harness made. Most retrofitter will do it for you there are also information from hidplanet about making your own harness
Old Oct 13, 2009 | 05:21 AM
aquatrax's Avatar
aquatrax
electric13,
I feel your pain, I don't know if I don't understand the "jargon" or no one is giving a straight answer.
Can you plug the OEM HIDs into the OEM stock wiring harness, yes or no?
If no, is there an OEM stock wiring harness to replace for the HIDs?
Old Oct 14, 2009 | 12:15 PM
electric13's Avatar
electric13
you hit the nail on the head!!!!! i know the connector is the same on both halogen and HID. i'm only wondering about the wire size. i can't imagine Lexus would put 18ga on one and 16ga (or whatever size is) on another based on the headlights because the harness runs to so many other things.
runscissor
Hybrid Technology
28
Oct 9, 2019 12:20 AM
hschultz
Dec 28, 2009 01:14 PM
gqr1c3boi
Mar 14, 2008 09:43 AM
skippy911
Lighting
Dec 19, 2005 06:35 AM
NT2SHBBY
Oct 16, 2004 07:45 AM
