help
Old Jan 23, 2009 | 08:57 AM
xanthax's Avatar
xanthax
Default help
i found out yesterday have a small leak in my rear passenger tire and today all these warning lights came on 1) brakesystem light, 2) abs light 3) vcs light and 4) low pressure tire light. is all related to the back tire or is my car in trouble.
Old Jan 24, 2009 | 01:18 PM
snhrph's Avatar
snhrph
Fix the leak in the tire first, and see if that corrects the other problems...
Old Jan 28, 2009 | 04:12 PM
grouch's Avatar
grouch
On 330's the TPS reads off of the ABS sensor for tire speed differential. I don't know about the 350's.
Old Feb 3, 2009 | 09:22 AM
xanthax's Avatar
xanthax
thanks guys.
Old Feb 3, 2009 | 10:18 AM
The G Man's Avatar
The G Man
RX330's tire pressure system is read off the tire rotation sensor and the RX350 is a direct system with a air pressure sensor on each tire.
Old Feb 4, 2009 | 06:45 AM
Grumpa72's Avatar
Grumpa72
Good advice but it always helps when you give the year and model. As suggested, the first thing should be to fix the leak and then, when the tire is remounted, reset the TPS.
Gary
Old Feb 18, 2009 | 08:04 AM
xanthax's Avatar
xanthax
thanks guys. sorry, it is an rx 330
Old Feb 18, 2009 | 04:53 PM
Grumpa72's Avatar
Grumpa72
So.... what did you do?
Old Mar 2, 2009 | 04:12 PM
ng8xzdt's Avatar
ng8xzdt
I just took my 2005 RX330 into the dealer for the same problem with the lights. The repair was for a faulty stop light switch assembly (part #84340-0E020). Several people on the forum also complained of this identical issue so I would take it in for the service.
Old Mar 3, 2009 | 08:14 AM
xanthax's Avatar
xanthax
faulty valve on the tire. The dealer charge me 75 bucks (Inc Taxes) to fix it. The service was great, but i probably could have gotten it fix cheaper if went to a tire shop.
Old Mar 3, 2009 | 07:24 PM
arnieosp's Avatar
arnieosp
No, you wouldn't. That sensor costs a lot.
xanthax
Wheels, Tires & Brakes Forum
Jan 23, 2009 09:01 AM
omr
Feb 23, 2007 03:53 PM
becca
Dec 9, 2006 02:02 AM
SC430GA
Jun 7, 2006 04:28 PM
