Clear , Red or LED .....
Old Nov 12, 2006 | 06:06 PM
sharpener's Avatar
sharpener
Default Clear , Red or LED .....
...... which type of rear lights look better?
need some advice, im on the red type currently, black car
im thinking of changing it to the LED type found on the RX 400h
any comments?
thank you
Old Nov 12, 2006 | 07:12 PM
norush's Avatar
norush
Tell us more, where do you get these led lights?
Is it just a simple swap?
Old Nov 12, 2006 | 08:29 PM
Kan-O-Z's Avatar
Kan-O-Z
Can you post some good pictures of what you have now. That might help us out a bit in giving you an opinion
Old Nov 12, 2006 | 10:58 PM
sharpener's Avatar
sharpener
im not quite sure abt the LED swap, hopefully its simple
i dun have the 400h model in my country, so all the images of the LED i have seen is on the net n thru lexus gallery
how was the actual look? different from our normal rear lights?
my car pics have aredi been posted, but here goes
Old Nov 13, 2006 | 12:37 AM
CK6Speed's Avatar
CK6Speed
FYI, the RX330 and RX350 doesn indeed use LED tail/brake lights, although it is not readily apparent and not the same LED style as the RX400H. Anyway, I like the red/clear pictured above the best.
Old Nov 13, 2006 | 08:20 AM
Kan-O-Z's Avatar
Kan-O-Z
To tell you the truth, the 400h lights are not very different from the 330/350 lights. One would have to be looking for it to even notice. The average driver would definitely not notice. By the way, the only time the 400h lights look even a bit different is at night when it's lit up...even then it's not all that different. In the day, it's very hard to notice any difference at all. I agree, the red ones you have definitely stand out and look much different than any of the clear ones.
Kan-O-Z
Old Nov 13, 2006 | 12:54 PM
Seadee456's Avatar
Seadee456
Do the 330/350s have both regular bulbs and LEDs in the taillights. I looked inside once when it was parked and there looked to be a light bulb inside. But when braking, the LEDs light up.
Old Nov 13, 2006 | 03:28 PM
CK6Speed's Avatar
CK6Speed
Yes, they have both a 168 I think 5W wedge bulb in the middle, surrounded by 5, or 6 LEDs. I partially opened mine up and could see the LED circuit board. The plastic casing also has the LED wording stamped on it. I've looked closely, and as far as I can tell the LEDs do light up both as tail lights and brake lights. They just get brighter when you hit the brakes when the lights are on.
Old Nov 13, 2006 | 10:40 PM
sharpener's Avatar
sharpener
for the RX 330/350 it uses normal bulb for lights n LED for braking
the RX400h uses LED for both lights n brakes
i agreed tat the LED of 400h, isnt tat big difference even to some RX owners
its just tat the red tail light have been mushrooming ard my state,n i want to stand out.
so, u guys think i shud just keep with it?
Old Nov 14, 2006 | 12:36 AM
CK6Speed's Avatar
CK6Speed
Yes, I think you should keep the red/clear. Aesthetically they are the best looking lights for the 2nd Gen RX IMHO. Even though they are a stock Japan part, it is still unique to the states, whereas the stock RX400H lights will just be another stock part.
Old Nov 14, 2006 | 02:50 AM
sharpener's Avatar
sharpener
hmm....
great advice there,CK6
actually we dun have any RX400h here, tats why im considering changing
btw, im not in the states
thanks guys, i know wat to do
keep the outer one in red, wherelese change the inner one to LED 400h, tat shud stand out
just kidding...
TonyLx570
LX - 3rd Gen (2008-2021)
Oct 9, 2020 05:35 PM
metrathon
Dec 3, 2016 11:34 AM
chris07is
Feb 21, 2014 07:42 AM
tony408
Oct 17, 2010 01:12 PM
