Did you notice the new LX570s have reverse LED lights? Does anyone know the part number for this?
Im thinking about upgrading. New LED Old non LED
Yes, from 2018 model year and up, the reverse lights are OEM LED now. However, to retrofit to prior model year will not only involve just the lights assembly, but also the trim pieces. You are better off just to replace the the bulb with LED will be much practice as I have done with my 2016 LX.
Assuming am ok replacing the trim pieces to upgrade my 2016 lx570 reverse lights to 2018 + led , do I have to worry about the bulbs being led? Will it just be plug and play with regards to the bulbs or Will I need resistors?
Here is what you need. Simple plug and play with LED bulb built in. Assuming your car is black or white. If not, have your local bodyshop paint it to match your car color. https://www.ebay.com/itm/Fit-For-200...UAAOSwlstd~EV0
I wouldn't be concerned, other than it's not an OEM Toyota part...simply Chinese crap...imo. I pass on Chinese parts on either our LX or Land Cruiser.
