program key fob (free, easy)
jayboydog
DefaultThe following works on my RX330.
You can sync the new key by yourself. no need for dealer, locksmith or special tool.
- sit in driver's seat, close all doors
- insert and remove a working key in the ignition four times and insert once more, leaving key in ignition.
- do not turn the key during the inserting and removing
- open driver's door and close six times (can press button in door frame)
- security lamp on dash should be solid indicating correct mode (if flashing, start over from inserting and removing key)
- remove working key
- insert new key, security lamp flashing
- wait until security lamp goes dark (60 seconds)
- new key is recognized by car and can start engine
I tried buying one from eBay it would not pair... then went to Noble lock and Key out of San Diego, they laser cut mine with pics I sent of my only key sent it out fast and cheap. They supply many locksmiths with their keys got a great price. Their key comes with the blade, plastic and transponder be very careful if you order elsewhere that you get all 3 components
https://www.ebay.com/itm/152605377465
Two cut keys for $50 from a photo!
I wouldn't believe it if I hadn't just got two keys and a programmer for $75 myself. The keys work perfectly. I thought I could program with out the $23 programmer but I couldn't. Looks like the above post may be able to do it without getting the programmer. Key fobs have same buttons as stock key and it even has a nice Lexus logo.
I AM NOT THE SELLER!!
jeronberna
RX - 4th Gen (2016-2022)
Jun 6, 2025 12:13 PM
tomtbone
GX - 1st Gen (2003-2009)
20
Feb 5, 2025 05:22 PM
