Quick question about radiator cap
Old Jul 30, 2022 | 11:22 AM
Androman's Avatar
Androman
Default Quick question about radiator cap
Hey all about to change my radiator, i ordered a new cap from lexuspartsnow and it says 108kpa on it, which is 15.6psi according to google, from what ive seen 16si is stock, i have fwd btw. Should i get a different one?
Old Jul 30, 2022 | 11:31 AM
Your cap doesn't look like this?
Amazon Amazon
Old Jul 30, 2022 | 12:17 PM
chuyrobles's Avatar
chuyrobles
https://www.amazon.com/dp/B00KTKNKB2
That shows 88 kpa on the cap, which is 12.8 psi. If 16 psi is stock, 15.6 is fine, 12.8 is not.
Old Jul 30, 2022 | 12:40 PM
That is the OEM part.
Old Jul 30, 2022 | 12:59 PM
Androman's Avatar
Androman
Nope, it says its the "replaced by" version, which is the most up to date part if im not mistaken, looks orange i used my vin on the website, says it fits my 2001 FWD
https://www.lexuspartsnow.com/parts/...tra2=&filter=()
Old Jul 30, 2022 | 01:27 PM
I did some part # checking Toyota/Lexus made a total mess of this, multiple parts change up multiple times. Depending on the year and model you may or may not get the same pressure rating.
Old Jul 30, 2022 | 03:09 PM
salimshah's Avatar
salimshah
25 Year Member
15.6 vs 16 is a small difference and the stated pressure is when the relief valve kicks in. The working psi is typically a safe distance away.
I would measure the diagram of the seal and the locking mechanism [it should not fit loose].
Salim
Old Jul 31, 2022 | 12:39 AM
Androman's Avatar
Androman
Salim
Well boys she's got a new radiator now, all put back together, so far no leaks, cap seems fine so far, now she just needs these lower control arms put in, just put on all new strut assemblies from FSC, I'll let y'all know how it goes!
I'd like to thank @thaeleelyr for the very informative guide
lexus-is2
Aug 12, 2021 01:01 PM
norviewguy
Feb 21, 2021 11:22 AM
jds4u2
GX - 1st Gen (2003-2009)
May 9, 2020 08:27 PM
Bradster
Dec 1, 2010 03:51 PM
