Replacement alternator advice wanted - RX300 2002
Old Mar 22, 2019 | 09:51 AM
oxonian's Avatar
oxonian
Default Replacement alternator advice wanted - RX300 2002
Hello,
Happy Spring to all of you. I have a 2002 Lexus RX 300 which about 195k miles on it. I recently had the transmission rebuilt, and the mechanic did a crappy job. I need to take it back to him as it is under warranty, lets hope he honors it.
It looks like I may need a new alternator, I think I may try to DIY with the help of some friends.
I checked Amaz**, EB**, and RockA*** for alternators, and they have TYC, PowerSelect or PureEnergy either new or refurbished, these are about $100-$150 depending on whether it is new w/o a core charge, or refurbished with a core charge (refundable).
Does anyone have experience with any of these brands or recommendations for any other brand/retailer to go with?
Thank you
Old Mar 22, 2019 | 11:12 AM
salimshah's Avatar
salimshah
25 Year Member
If you are in Austin, I can give you the brush set. You can get the diode pack and if the slip rings are good, you can reconstruct the old alternator.
Salim
Old Mar 22, 2019 | 02:24 PM
oxonian's Avatar
oxonian
Thank you Sir, always nice to hear from you. I am not in Houston, I wish I were closer to you!
It looks like I will have to opt for a new or refurbished, but not sure which brand etc. to choose?
The car is just sitting in the driveway I don't want to risk driving it, it turns on and can drive, but I am sure the battery will deplete charge rapidly.
Thank you
Old Mar 22, 2019 | 05:39 PM
TrueGS300's Avatar
TrueGS300
I just put the TYC brand in mine. Working fine but I'm not sure I'd recommend it.. Seems to be a little noisy. I'm giving it time to settle in. But if it gets worse, it's coming out.
Old Mar 22, 2019 | 05:41 PM
oxonian's Avatar
oxonian
Thank you
Did you get it online? If so, are you able to share which vendor?
Old Mar 22, 2019 | 06:08 PM
TrueGS300's Avatar
TrueGS300
It was an ebay order, just whoever had it. sixityauto is the name of the seller
Old Mar 23, 2019 | 09:33 AM
ricco750's Avatar
ricco750
HIGHLY recommend the Denso Reman from RockAuto. Yeah, it costs a little more, but WELL worth it. I replaced the alternators in both my '99 RX and my '02 Highlander two years ago just as preventive maintenance...I don't like to wait until a part fails before I replace it...they worked perfectly, like new. I also noticed subtle improvements like no dimming of the headlights when the brakes are used. I'd stay well away from the "offbrands" you mentioned.
Old Jul 17, 2024 | 05:01 AM
Rudy602's Avatar
Rudy602
Does anyone know the Denso alternator model # for a 2002 RX300? I can't read the label on mine. Is there more than one possibility? 210-0439? 210-0509? Is there a rebuild kit available? Mine has what sounds like some bearing noise but is still working. Thanks.
Old Jul 17, 2024 | 08:25 AM
salimshah's Avatar
salimshah
25 Year Member
There are two alternators [not sure if they share the pulley size --> belt?] but one is standard and the other is high output. You can visit on line retailers like Bell Lexus of Arizona and punch in your vin to get the right alternator.
I serviced mine with new rectifiers, regulator and brushes. It is very easy to service [I did not need to replace bearings, so cant comment on level of difficulty to remove the bearings]. The only bad experience was that the seller fulfilled partial order and I had to pay a second retailer for shipping for the remaining. Please instruct seller not to sent partial [live and learn for me].
I prefer self service over rebuilt. Buying a new one is way too expensive.
Unrelated but might impact you .... make sure it is the alternator that is making the noise. You can remove the accessory belt for few minutes to mechanically isolate the alternator. In any case, I highly recommend that you remove and bench test [for free] the alternator. Mine was functional but not good enough as a few diodes popped.
Salim
Old Jul 17, 2024 | 10:21 AM
Rudy602's Avatar
Rudy602
Good idea to have it tested. Thanks. Is there a parts breakdown or diagram of the adjustment mechanism? It’s underneath the alternator so I can’t see it. I snapped the short bolt trying to loosen it.
Old Jul 17, 2024 | 11:05 AM
maxSteel's Avatar
maxSteel
It's in the DIY: https://www.clublexus.com/forums/rx-...djustment.html
Old Jul 17, 2024 | 12:55 PM
salimshah's Avatar
salimshah
25 Year Member
Dint overlook the basic setup. Mounting and fastening nut/bolts & adjustment. One must loosen the mounting fasteners before moving the adjustment nut. Adjustment nut must be loosened to free up tension on the belt.
If done out of order the adjustment mechanism will break off.
Salim
PS: At the end, the mounting bolt/nuts must not be snug when adjustment in tension is done. Then the mounting bolt/nuts are tightened.
crb5kb
Nov 9, 2019 05:06 PM
kaydeee
13
Feb 28, 2018 04:06 PM
JohnLX300
Mar 27, 2013 05:25 AM
Rock-a-Lex
Mar 10, 2011 11:57 AM
LiqrSicc
Apr 4, 2006 08:51 PM
