Need help asap brake failure
Old Jun 10, 2017 | 11:41 AM
salimshah's Avatar
salimshah
25 Year Member
Originally Posted by RX469
Hello Salim, can you expound on this as I've never heard of it before and where would find this diagnostic port? If I'm understanding this correctly, this is not the same as the OBDII port that's steering wheel/dash?? Thanks.
Lexus has a scan tool which connects to DLC2 [round shaped] connector located under left side of instrument panel.
Warning light method is:
use a fused jumper to bridge DLC1 [rectangular DIAGNOSTIC port [in the engine bay] pins E1 to Tc OR on DLC2 connector Tc to E.
Turn ignition ON ... ABS or Trac light will begin to flash and give you the error code.
4sec pause- First Digit Error code # flash -- 1.5 sec pause --- Second Digit code # flashes
2.5 sec Puase
sequence of flashes for additional error codes or repeat of the single error.
If every thing is fine --> 2 sec pause -> blip every .25 sec [no elongated pauses].
Salim
Caniac14
Aug 29, 2014 10:11 PM
n0sGS300
Dec 13, 2012 12:47 AM
thegr8one
Dec 4, 2009 08:50 AM
jdm_monkey
GS - 1st Gen (1993-1997)
Sep 28, 2007 10:30 AM
